what did you do to your 675 today???? - Page 876 - Triumph675.Net Forums
post #8751 of 9275 Old 12-20-16, 10:50
jubei4769
Did a coolant flush, gotta replace the intake tube as the top two nuts have broken the plastic so the tube sags. Ugh another 2-3 weeks waiting for parts
jubei4769 is offline
post #8752 of 9275 Old 12-20-16, 14:13
Gsatterw
Putting the stock tire back on the bike - bozo I bought it from had a 190 on it, worn all the way in the center. Did not turn well.
Gsatterw is offline
post #8753 of 9275 Old 12-20-16, 14:27
littlehat
littlehat's Avatar
Dropped my forks flush and put the rsr rear link. Not quite sure if I need to do anything to the stock r shock length or not yet. Anyone have pointers for the rsr link? I got it second hand, but it seems there's not many of out there since they are expensive new.
Sent from my SM-G900V using Tapatalk
littlehat is offline
post #8754 of 9275 Old 12-20-16, 19:01
swantombomboy
swantombomboy's Avatar
New plugs, chain , and wheels. Wow what a difference a good set of tires makes!
-- San Diego --
swantombomboy is offline
post #8755 of 9275 Old 12-29-16, 02:23
ramnakhle
ramnakhle's Avatar
Sato Racing Sliders - Finally
Installed:
Sato Racing frame sliders
Sato Racing engine sliders
Sato Racing fork sliders
Sato racing swingarm spools
I got Sato Racing bar ends and inner weights. Will install once I figure out how to take out the stock ones
Any help??
By the way, has anyone tried the inner weights? Any difference?
Cheers & ride safe
ramnakhle is offline
post #8756 of 9275 Old 12-29-16, 21:46
20161022
Originally Posted by ramnakhle View Post
Installed:
What a coincidence! I was just debating whether or not I should get the R&G Aero sliders or the sato sliders.
Any reason you chose Sato?
20161022 is offline
post #8757 of 9275 Old 12-29-16, 22:00
jubei4769
Installed my cf rear mudguard
post #8758 of 9275 Old 12-29-16, 23:19
ramnakhle
ramnakhle's Avatar
Well first and foremost I like the way they look; So many opinions on sliders out there...
I like the Delrin plastic they use. Feels very slippery and that's what you want form a crash slider. Some manufacturers use hard rubbers and for some reason I always imagined these will catch on the pavement and flip the bike in a crash... But that's just my imagination and probably not very scientific...
So basically i chose these because they have an excellent finish and I liked the way they looked on the bike... and the fact that I fount the whole matching set
Hope this helps
post #8759 of 9275 Old 12-30-16, 16:16
20161022
Hope this helps
Thanks for the input - The Sato sliders definitely look a bit better than the R&G
I think your logic is pretty sound regarding catching on pavement, but I don't track so I could be wrong.
I guess if I don't track either one of them will do just fine?
20161022 is offline
post #8760 of 9275 Old 12-30-16, 17:48
Benisuzume
Benisuzume's Avatar
Finished the reflective red honeycomb printed vinyl wrap on my lower fairings...took about 2 hours per side since reflective vinyl is nearly impossible to wrap...
It's difficult to tell from the photo with the sun, but the base reflective vinyl color is a near perfect match to the red on the tail frame. It also has a matte laminated finish to match all of the other matte surfaces. Now on to the next mod!
Benisuzume is offline
