URL:s to Tuneboy and PCIII tunes for 675 - Page 28 - Triumph675.Net Forums
post #271 of 276 Old 05-09-11, 19:10
pentaxis
pentaxis's Avatar
Thanks Roffe! Ended up getting a dyno tune completed already. Might eyeball it for the L Tables though.
Just have to sort out why I can't seem to get the TPS to reset properly now. Getting crazy wierd surge at 5k-5500 with 1-5% throttle. Definitely a TPS related issue I think as the timing and fuel is all dialed.
pentaxis is offline
post #272 of 276 Old 06-07-11, 03:49
caliace
caliace's Avatar
The link to Wayne MacDonald's Jardine tune is down, does anyone have a copy they can sent me? Its for a 2006 675. thanks!
caliace is offline
post #273 of 276 Old 08-05-11, 09:47 Thread Starter
roffe_s
roffe_s's Avatar
New Str3 dyno files for TuneECU
Dave73 have been kind enough to translate a couple of Dyno tunes for the Street triple, as well as his own, modded setup. His file may be downloaded from the first post (right-click and save).
Thanks for sharing, David
roffe_s is offline
post #274 of 276 Old 09-30-12, 15:34
fightforlife
Hey guys,
iread the whole thread because im searching for the right tune, to use with my bike!
My bike is from 2006 (first VIN range). It has: Mivv-slipon, MWR-foam filter, removd cat, removed exup, removed intake flapper.
The O2-sensor as well as the SAI could be removed if it fits the tune better.
The Problem is that i only have TunECU,but no TuneBoy.
Is there some way to get these tunes via TuneECU?
Roffe said smething about that:
Hi,
I updated the TuneECU file for the 20110-guttedcat-TBR-map so it may be downloaded from the site (in .rar compression). However, You need to eliminate the O2-sensor manually in order to make it work properly on Your bike.
Good luck.
fightforlife is offline
post #275 of 276 Old 12-15-12, 03:01
Daytonadick675UK
I've got the TOR exhaust on d675 2008 just had the cat an exup cut out what tune do people suggest
Daytonadick675UK is offline
post #276 of 276 Old 12-15-12, 03:02
Daytonadick675UK
Also running k&n air filter too
