URL:s to Tuneboy and PCIII tunes for 675 - Page 2 - Triumph675.Net Forums
post #11 of 276 Old 03-06-08, 16:16 Thread Starter
roffe_s
roffe_s's Avatar
Originally Posted by PragB View Post
...I opened 20208, clicked for it to apply the pcIII map and adjusted for the speedo correction, but as far as the map itself it appears that none of the figures in the 20208 map is actually changing... Any ideas?
PragB - have You looked in the "fuel % trim" - table after applying the PCIII-map? There is where the changes in the PCIII will stay (in %) until You choose to "Commit the changes to main table".
20203 is probably the correct tune to use as 20108 was the std tune for the -06.
I tried the files on my computer and it worked just fine!
Good luck - If it still bothers You, PM me and I'll send You the file;-)
roffe_s is offline
post #12 of 276 Old 03-06-08, 17:53
PragB
PragB's Avatar
Send a message via AIM to PragB
when I open my tuneedit I dont have the options on the page to switch between fuel map, ignition limit, fuel%trim etc... I have tunedit 3.5.0
edit: ok nevermind I now have it in advanced mode...
edit: ok... I think I finally got it now... Thanks...
PragB is offline
post #13 of 276 Old 03-08-08, 02:37
Jim675
MODs you should sticky this thread, and allow us to pm new tunes to you that way it will be organized not like the other thread.
Jim675 is offline
post #14 of 276 Old 03-14-08, 18:40 Thread Starter
roffe_s
roffe_s's Avatar
First post updated with some popular requests. Last updates are marked with italic fonts.
roffe_s is offline
post #15 of 276 Old 04-14-08, 06:44 Thread Starter
roffe_s
roffe_s's Avatar
First post updated with Waynes Str3 Arrow tune.
roffe_s is offline
post #16 of 276 Old 04-15-08, 16:37
toxidomask
Talking
awsome post, this will be very useful. Thank you sir you have done a lot in this forum!.
toxidomask is offline
post #17 of 276 Old 04-15-08, 18:11
Evil675
Evil675's Avatar
Send a message via MSN to Evil675
Does anyone have a decent Tuneboy Map to run with the Shark Pipes? Or which of the above would be best suited as a starting point?
Thanks
Evil675 is offline
post #18 of 276 Old 04-16-08, 04:52 Thread Starter
roffe_s
roffe_s's Avatar
While waiting for an input from a Shark owner, Ducnut is( still?) running Shark with TOR tune and made a dyno run with AF log on Hordboys dyno in the thread https://www.triumph675.net/forum/show...highlight=dyno
It seems to work quite well, if You would like to gain some smoothness or maybe the last hp, one of the other slip-on maps might add some value.
However, this is yet to be verified by a Shark- and Tuneboy owner
My 2p
Thanks
roffe_s is offline
post #19 of 276 Old 04-16-08, 04:59
Evil675
Evil675's Avatar
My 2p
Sounds like I shall be having some testing fun once I get myself a TB (hopefully the GB takes off shortly) and I'll see what we come back with!!
I'll quite gladly be your guinea pig ... will see if any of the places here in Perth have much experience with the TB and look at a custom map to suit.
Good times to come
Evil675 is offline
post #20 of 276 Old 04-24-08, 14:49
ggillies
ggillies's Avatar
GRRRRR.... This tune
Arrow full system
Wayne M have a dyno tune for this setup that get rid of the popping at decel. Dyno chart and link to the map can be found via this post: https://www.triumph675.net/forum/showpost.php?p=250458&postcount=18
Seems to be for a Street Triple??? I tried loading it and got an error message telling me it was the wrong ECU type???
I'll e-mail Wayne and find out what his take is...
2011 Motorsports Color BMW S1000RR; Full Akrapovic EVO Ti system with PCV and Dan Kyle map, BMC race filter. 192 RWHP. Pazzo shorties, BMW tank protector.
2011 Triumph Daytona 675R; carbon tank protector, R&G sliders..
2009 Tornado Red. 2009 Arrows Slip-on, High-Octane Triumph tune, Carbon Fiber heat shield, Pazzo shorties black/red, Stompgrips, Triumph Carbon Tank protector.
ggillies is offline
