2015 front sprocket, 06-12 same? - Triumph675.Net Forums
post #1 of 7 Old 05-06-19, 14:38 Thread Starter
jdgun_13
jdgun_13's Avatar
Ordered a 520 renthal sprocket for the 2015 motor i have, and well there is about .2mm gap (freeplay), as the nut runs out of thread before tightening it down.
Has anyone had this issue?
I "could" put the nut on with the recessed portion against the sprocket but that is not how it is intended.
Is the 2006-2012 the same sprocket?
Most of you people are not capable of being your GD self, to damn worried about being politically correct.
2015-MV Agusta F3 800
2011- Triumph Daytona 675R
jdgun_13 is offline
post #2 of 7 Old 05-08-19, 16:03
Harsh
Harsh's Avatar
According to the p/n listed on bike bandit they are not the same for 06-12. However, that is more than likely because there is a gearing change from 16 to 15 teeth. I am willing to bet the spline and spacing is the same between gens. The P/N for the 1st Gen is T1180182 and it shows that it fits the 2013 Daytonas as well as a bunch of other bikes. The P/N for the 2015 is T1182011 and shows it is for 17-13 Daytonas.
However, to fill the gap I would be very tempted to add an additional washer.
1st gen: https://www.bikebandit.com/oem-parts...540463?m=17634
2015: https://www.bikebandit.com/oem-parts...126639?m=17634
Other People's Kids
Harsh is offline
post #3 of 7 Old 05-08-19, 17:01
cdenley
2013 Daytona's up to VIN 564947, so the 2nd gen ones made in 2013. All parts for 2nd or 3rd gen show fitment for 2013 depending on the VIN.
Chris Denley
CCS Midwest Amateur #212
fb.me/DenleyRacing
cdenley is offline
post #4 of 7 Old 05-12-19, 14:03 Thread Starter
jdgun_13
jdgun_13's Avatar
At this point i am going to add a a very thin washer to remove the slack between the crush/safety washer and sprocket..
jdgun_13 is offline
post #5 of 7 Old 05-14-19, 14:41
Greg57vw
The recess goes against the sprocket. The output shaft sticks out past the washer. The recess allows the nut to tighten on the shaft.
Greg57vw is offline
post #6 of 7 Old 05-14-19, 18:38 Thread Starter
jdgun_13
jdgun_13's Avatar
Never had a bike that used the recess portion before to put pressure on the sprocket, I know my 2012 675R did not. Oh well going to slap it on that way for now, as want to get the bike together.
jdgun_13 is offline
post #7 of 7 Old 05-15-19, 02:43
Greg57vw
From the haynes manual Daytona 06-12 street triple 07-16
Sent from my BLA-A09 using Tapatalk
Greg57vw is offline
The Following User Says Thank You to Greg57vw For This Useful Post:
jdgun_13 (05-15-19)
