HOW TO: 675R Ohlins fork disassembly (for oil/spring change) - Page 3 - Triumph675.Net Forums
post #21 of 28 Old 11-03-17, 01:36
Originally Posted by Wiggie View Post
Anybody have a set of stock .95 springs for the 675R that they replaced and would want to sell????
Pretty sure I have some stock springs. I'll dig through my spares box tomorrow.
post #22 of 28 Old 11-03-17, 14:58
jdgun_13
jdgun_13's Avatar
if you don't I think I have some.
Most of you people are not capable of being your GD self, to damn worried about being politically correct.
2015-MV Agusta F3 800
2011- Triumph Daytona 675R
jdgun_13 is offline
post #23 of 28 Old 11-03-17, 15:00
I do. Eff off!
The Following User Says Thank You to MGFChapin For This Useful Post:
jdgun_13 (11-03-17)
post #24 of 28 Old 11-03-17, 21:37
Ditch Doctor
Ditch Doctor's Avatar
^ hahahahah ??
Good to see you around @jdgun_13
That Others May Live
Ditch Doctor is offline
post #25 of 28 Old 11-03-17, 23:17
Shamrock
Mean Green Mod
Shamrock's Avatar
:D Like 2 bickering cousins. Always arguing, but lovingly. :)
Shamrock is offline
post #26 of 28 Old 02-02-18, 15:39
Avanti
Avanti's Avatar
My 2014 675R has the FG R&T 43 forks. As an alternative to compressing the spring to loosen the jam nut, I modified a spare 17mm wrench (see attached photos) so that I can hold the jam nut with the upper seat (aka spring support) in place as is indicated in the service manual on page 12.19.
ID:	241826   Click image for larger version
Avanti is offline
post #27 of 28 Old 02-11-18, 18:57
Phicurious86
Phicurious86's Avatar
What was the purpose of the cartridge pull up tool? Did you think it was necessary?
Phicurious86 is offline
post #28 of 28 Old 02-11-18, 19:23
You need it to pull the damper rod above the fork tube to thread the cap back on. You also need it to pump the rod up and down about a dozen times to bleed the air out. You could probably handle the job without the tool but it would take a lot longer and your fingers would be banged up/exhausted by the time you're done.
Phicurious86 (02-12-18)
