turn signal woes - Triumph675.Net Forums
post #1 of 8 Old 07-28-19, 12:23 Thread Starter
siq75
Question turn signal woes
I purchased a set of flush mount signals from this guy https://www.675.cc/675/threads/2006-...s%C2%AE.29120/
When I plug them in, 4 little led's stay lit on each signal, and when I turn on either the left or right turn signal, all of my lights(side markers&tail light) flash at the same time like 4 way flashers/hazards on a car. This happens with my Motodynamic flasher relay and the stock relay(except they are fast blinking).
My stock turn signals, my brothers Watsen Design signals, and some cheap ebay signals all work properly on my bike. Now here's the kicker, when I plug these lights into my brothers 675 that I took the Watsens off of, they work fine. So how it is that every turn signal works on my bike except these, and how can these work on another bike if they don't work on mine?
I'm lost!
Daytona 675 TRIPLE SE
siq75 is offline
post #2 of 8 Old 07-28-19, 13:36
Stephen Pilsworth
Have you tried swapping indicator relays with your brother's bike as well?
Sent from my Swift 2 X using Tapatalk
Stephen Pilsworth is offline
post #3 of 8 Old 07-28-19, 13:38 Thread Starter
siq75
No I haven't, that will be the next thing I do. Hopefully the relays are the same, my bike is gen2, his is gen3.
siq75 is offline
post #4 of 8 Old 07-28-19, 13:42
Stephen Pilsworth
Don't think generation should matter but that would be my first thing to try.
Also when you swapped did you swap all the indicators or just one?
Other than that I'd say steal his watsens as they are so much better than other flush ones
post #5 of 8 Old 07-28-19, 13:48 Thread Starter
siq75
I did swap all the indicators, swapped them from side to side, reversed the wires, I tried everything, except his relay which I will try to get at today.
siq75 is offline
post #6 of 8 Old 08-04-19, 17:21 Thread Starter
siq75
Swapped over the relay, still having the the same problem. I'm stumped!
siq75 is offline
post #7 of 8 Old 08-05-19, 00:53
Stephen Pilsworth
Such a weird issue. I'm stumped and I'm sure you've tried one signal at a time, but if the old ones work I have no idea.
post #8 of 8 Old 08-05-19, 17:26 Thread Starter
siq75
Well **** me then!
siq75 is offline
