HOW to Fix Regulator/ Rectifier - Page 5 - Triumph675.Net Forums
post #41 of 48 Old 07-04-11, 03:56
Depending on the assembly quality of the unit and the amount heat exposed even the good Mosfet units are known to fail. I'm not talking about the Triumph units specifically but all bikes in general. They make these units extremely small and so they have to dispense a lot of heat and then manufacturers try to hide them because they're ugly. Hiding them usually means reduced air flow and I think you can get the picture.
MacBandit is offline
post #42 of 48 Old 07-05-11, 15:27
DGray
DGray's Avatar
Originally Posted by Ruby Racing View Post
It happens because the old style R/R's are sh!t. The ones fitted to later models are a different make and hopefully shouldn't cause a problem.
Just hope for the best though. Still, after reading this, it just plays around in my mind. Maybe the older models, its more of where the R/R is located?
DGray is offline
post #43 of 48 Old 07-05-11, 23:33
Location is important but they clearly had a batch of bad units. The design itself is not a problem as bikes of all kinds have been using shunt type rectifiers for decades without issue.
post #44 of 48 Old 03-24-17, 23:01
jb.junior
jb.junior's Avatar
Good, albeit, old thread. Thanks for all who contributed.
jb.junior is offline
post #45 of 48 Old 07-20-19, 09:11
Mac
Digging up this old thread,
Has anyone had success just repairing the wiring from the R/R?
My 2011 had no issues with electrical power or warning lights, just melted the wires at the 3 pin connector where yellow wires meet black. No external evidence of R/R damage.
Mac is offline
post #46 of 48 Old 07-20-19, 09:31
Stephen Pilsworth
I have, had wires melt just before the plug coming from the stator and close to the reg/rec.
My fix was to cut the plugs out and out in connectors for each wire. Voltage was steady at 14.5 when bike is running, was clearly facing resistance as it was lower until I removed the plugs.
Sent from my Swift 2 X using Tapatalk
Stephen Pilsworth is offline
post #47 of 48 Old 07-21-19, 16:14
Tomuza
Tomuza's Avatar
I noticed some newer style butt end connectors on the market. they are actually a solder connection and heat shrink all in one... gonna get some and try them out.
I have been hard wiring (directly soldering wires) on V65 Magna's for years to eliminate the burnt connector issue...
no plug, no more heat melt issues at that connection.
I've also used mosfet R/R upgrades on all VFRs, and my D955i with larger guage wire all the way from stator and the appropriate mosfet plugs (like De'course method) with 100% success!
Tomuza/Greg
Middle Tennessee/Upstate SC
08 D675, 02 D955i, 02 R1, 91 VFR,
97 VFrc30, 85 V65 Magna, 02 Sv650s
Tomuza is offline
post #48 of 48 Old 07-24-19, 09:19
Larzzz
Send a message via AIM to Larzzz Send a message via MSN to Larzzz Send a message via Yahoo to Larzzz
arnt the rectifier's replaced for from from Triumph? There is a recall
Larzzz is offline
