HOW TO: Free a Seized EXUP Valve - Page 2 - Triumph675.Net Forums
post #11 of 151 Old 07-19-08, 03:43
chielmi
chielmi's Avatar
Excellent post! Thank you very much. My valve hasn't seized yet, but it squeaks like hell. Now with your how-to I will lube the bearings with a lot of grease to prevent it from seizing :)
Edit: Squeak is gone now!
chielmi is offline
post #12 of 151 Old 07-19-08, 05:25
XXVII
XXVII's Avatar
The HOW TO's are the best. I've started to PDF the first page of most of the threads that still have pictures, as I have noticed that some of the older posts no longer have the images present. A good example would be the HID fitting.
I should either post the PDF's or I might start hosting them myself.
XXVII is offline
post #13 of 151 Old 07-19-08, 06:05
AsphaltScraper
Chiperator
AsphaltScraper's Avatar
If you could that'd be kickass, or tell me how to convert the threads into pdf's?
AsphaltScraper is offline
post #14 of 151 Old 07-19-08, 06:33
XXVII
XXVII's Avatar
I'll organise the hosting soon, and put all the PDF's up once it is finished.
In reagrds on how to PDF the tread, that is the easy part.
Download PDF Createor from the following address:
http://www.pdfforge.org/products/pdfcreator/download
Install PDF Creator. This will install a PDF print driver in your "Printers and Faxes".
To output a page as PDF, just print it and select the PDFCreator Printer as the printer.
BTW, you can use PDF Creator to output ANYTHING that you would normally print as a PDF and the best part is that it is FREE.....
Hope that Helps....
XXVII is offline
post #15 of 151 Old 07-19-08, 08:44
qweesy
qweesy's Avatar
thx I started to hear this loud squeak like 3 weeks ago
qweesy is offline
post #16 of 151 Old 07-19-08, 13:41
tooblekain
tooblekain's Avatar
You are the MAN!!! I was hoping someone would do a write up on how to do this since my warranty expired and Ive had to go to the dealership twice because of this.
My biggest thanks!!!
tooblekain is offline
post #17 of 151 Old 07-19-08, 14:59
PragB
PragB's Avatar
Send a message via AIM to PragB
I dont have one anymore, but I had to post up that this is an excellent How-To... And even though I don't get use of it, I must thank you for taking the time to put this together for others!!!
PragB is offline
post #18 of 151 Old 07-21-08, 06:05
ScarfaceClaw
ScarfaceClaw's Avatar
You are a super star.
This space for rent.
ScarfaceClaw is offline
post #19 of 151 Old 07-21-08, 16:23
ollie
That will be useful...thanks
ollie is offline
post #20 of 151 Old 07-21-08, 18:07
bballman01
bballman01's Avatar
Send a message via AIM to bballman01
mines just started squeaking so ill be trying this tomorrow. thanks
If ur not ridin' ur not livin'
bballman01 is offline
Tags
exbv , exhaust valve , exup
