SAI Plumbing - Triumph675.Net Forums
post #1 of 41 Old 10-29-11, 00:29 Thread Starter
xxdevilzeroxx
xxdevilzeroxx's Avatar
SAI Plumbing
Is this correct mac! should i buy new hoses and make it look fancy, or keep this OEM set-up
1- took off the SAI unit
2- Flipped the hoses to go towards the right
3- trimmed the crank case hose
4- got a half inch adapter to connect both
5- clamp both hoses
6- plug air box holes
7- update SAI on tune ECU and erase code - download to ECU
xxdevilzeroxx is offline
post #2 of 41 Old 10-29-11, 00:37
horra
horra's Avatar
Thats how i done mine the easy way
horra is offline
post #3 of 41 Old 10-29-11, 00:47
MacBandit is offline
post #4 of 41 Old 10-29-11, 00:55 Thread Starter
xxdevilzeroxx
Yes. That's perfect.
thanks mac!
post #5 of 41 Old 11-03-11, 13:59
timwu12
timwu12's Avatar
can I ask how you plugged the holes on the SAI units and the airbox hole?
Also, where's the crankcase hose located?
timwu12 is offline
post #6 of 41 Old 11-03-11, 15:55
carnage.inc
carnage.inc's Avatar
Driven sells a block off kit for thirty four dollars us. Bought mine through opp racing. Would have just done it with the hoses like you did but hot exhaust gasses pushing back on rubber hoses isn't a good thing.
Sent from my MB612 using Motorcycle App
carnage.inc is offline
post #7 of 41 Old 11-04-11, 05:16
JazMan
JazMan's Avatar
The reed valves in the SAI ports should prevent any hot gases from entering the rubber hoses .
A Rossi fantasy and PeeWee Herman skills !!!
ASMA #66
IBA # 44791
Original 6 AZ Dirty Aces
JazMan is offline
post #8 of 41 Old 11-04-11, 13:55
^^^ What he said. The way the PAIR valves (reed valves) there is actually a vacuum inside the tubes not positive pressure.
post #9 of 41 Old 11-10-11, 04:17 Thread Starter
xxdevilzeroxx
Vacuum caps from auto stores, im not sure what size the SAI hose is.. anyone know?
post #10 of 41 Old 11-26-11, 06:58
SelYal
is there a how to regarding the sai removal & blocking on this forum? I just purchased a Bazzaz Z-FI QS TC and as far as I understand, in order to tune the fuelling, it's necessary to remove the SAI. Any help would be highly appreciated.
SelYal is offline
