Idle speed discrepancies - Triumph675.Net Forums
post #1 of 5 Old 05-21-20, 23:28 Thread Starter
TheBeerHunter
TheBeerHunter's Avatar
I have a hotter motor and custom tune with the idle set at 1900rpm. The bike runs fine until i give it throttle then the rpms drop to maybe 1000 amd occasionally dies. Opinions on if this is a tune issue or just needs an idle stepper adjustment?
TheBeerHunter is offline
post #2 of 5 Old 05-22-20, 11:52
TTRIgnitionSystems
Site Sponsor
TTRIgnitionSystems's Avatar
*drums fingers* If this was a carb'd bike, I'd say your pilots were fouled or your mixture screws were too lean. If you have TuneECU or similar, try adding a little fuel at the bottom.
Also, 1900 strikes me as a little fast.
TTRIgnitionSystems is offline
post #3 of 5 Old 05-22-20, 15:02
Stephen Pilsworth
1900 sounds way too high.
I know the idle will drop to just above 1000 when really hot but ideally 1200-1300 is ideal.
I had issues with low idles and it did my ****ing head in so I installed a manual idle and set it up to work with the stepper motor in the way it would stop the idle dropping below a set amount. Works a treat now.
Stephen Pilsworth is offline
post #4 of 5 Old 05-27-20, 11:41 Thread Starter
TheBeerHunter
My tuner deliberately set idle at 1900 for wheel hop and corner speed purposes.
post #5 of 5 Old 05-27-20, 14:34
TTRIgnitionSystems
Site Sponsor
You're effectively riding with a cracked throttle when you should be fully closed. This can have unfortunate consequences if the bike accelerates under a closed throttle when you let off the brake.
