1050 throttle tube installation? - Triumph675.Net Forums
post #1 of 116 Old 09-30-08, 08:46 Thread Starter
triplesins
triplesins's Avatar
Send a message via AIM to triplesins
does any one have pics or diagram to do this?... i wanna have it done but the dealer i deal with said they dont really wanna do it for liability reasons, so i wanna do it myself... but havent gotten that far into taking my bike apart or kn owing how...
any info on it>??
triplesins is offline
post #2 of 116 Old 09-30-08, 09:11
MrChris
MrChris's Avatar
It's supper easy use an Allen wrench to remove the bar end slider. but you have to hold the slider while loosening so that it doesn't just keep going around and around. move the rubber grommet thing off the housing by simply pushing it back onto the cables. then remove the two screws underneath the housing(i took this opportunity to put on new hand grips. putting the new ones on the tube before installing). see how the cable align on the OEM tube. take those off then take the new 1050 tube slide it on pace the cable on it and revers the steps before.
but leave the two screws on the housing a little loose so that you can adjust it because the grip will sometimes grip the bar end and thats not good. so just keep messing with it untill it no longer grips the bar end and looks good
tighten the two screws and in about 30 mins you've gotten way better throttle response.
MrChris is offline
post #3 of 116 Old 09-30-08, 09:40
flaudia402
It literally will take you no more than 10 min to do it, if that. Just make sure you don't strip the stupid phillips heads screws!!
flaudia402 is offline
post #4 of 116 Old 09-30-08, 09:43
eden.kwok
theres a tread going on here about installing, one its dead easy, just make sure you have enough cable so that the throttle closes.
eden.kwok is offline
post #5 of 116 Old 09-30-08, 09:53
eden.kwok
cant seem to find the how-to anymore, but heres something that may help with exploded diagrams etc.
https://www.triumph675.net/forum/show...le+tube&page=1
post #6 of 116 Old 09-30-08, 15:36
CT_D675
yeah, just did that 2 nights ago .....f'n kicking myself for using the wrong size phillips head screwdriver. I got the 1st one out fine, but the 2nd was being a stubborn *****.
Now I'm debating whether to try an ezout or something like that. How badly did you strip yours?!
'08 Daytona 675 SE
T-Rex Spools | Triumph Gel Seat | Pazzo Levers | TechSpec Grips | HID
CT_D675 is offline
post #7 of 116 Old 09-30-08, 23:52
adam0311
Seriously easy mod. took maybe 10 minutes and I'm an idiot mechanically.
very fun mod though. makes the mono even easier than before.
adam0311 is offline
post #8 of 116 Old 10-01-08, 00:09
DieselDan
deff going to do this over the winter
DieselDan is offline
post #9 of 116 Old 10-01-08, 18:22
BuckeyeD
BuckeyeD's Avatar
Send a message via AIM to BuckeyeD
i have a question to add... when you go to the dealership to buy the tube, does it come with the grip and is the grip the same as the daytona's?
BuckeyeD is offline
post #10 of 116 Old 10-01-08, 18:23
Socket
Socket's Avatar
I bet this has only be done once or twice before, so searching wouldn't come up with ANY info...
/sarcasm
'09 Aprilia RS125 street bike - sold
'03 SV650 track bike - sold
'03 ktm 250sx-sm (track bike) - sold
'07 Daytona - sold
Socket is offline
