Dash electric acting funny - Triumph675.Net Forums
post #1 of 4 Old 06-23-19, 14:54 Thread Starter
Patte90
I'm having a small issue with my 2008 ST, sometimes when you turn ignition on, dash screen, fuel pump etc are dead. What makes it interesting is that side indicators and horn still work! So anybody have anything similar happen to them? I'm bit torn is the problem in dash or might it be in ignition lock itself.. Anyway need to check the wires on both!
Thanks for advice and answers in advance!
Patte90 is offline
post #2 of 4 Old 06-23-19, 23:34
ramnakhle
ramnakhle's Avatar
Does it crank?
How old is your battery?
Crapped out batteries can make some very odd behavior on these bikes.
Id check that out before going any deeper.
ramnakhle is offline
post #3 of 4 Old 06-24-19, 10:17 Thread Starter
Patte90
No it doesn't crank, it's as if everything between the dash and engine is dead.
The issue I doubt is the battery, it's practically new. ( Fu*ked up my previous battery by not using the charger on winter break :D)
Patte90 is offline
post #4 of 4 Old 06-24-19, 10:24
MadMel
MadMel's Avatar
I'd check the battery and ground wiring under the seat, make sure there isn't a loose connection.
MadMel is offline
