Recommend a front paddock stand? - Page 3 - Triumph675.Net Forums
United Kingdom UK Forum, rides, get togethers and events
post #21 of 27 Old 06-08-15, 07:26
phatplat
phatplat's Avatar
Originally Posted by VK56DEHAN View Post
Never used a headlift stand....seems they would be more stable, are they universal? Cycle gear has a pitbull head lift for $189 and know they do military discount. Luckily I was cautious and had my wife there to help when I first tried to lift it with the fork stand. I was lucky enough for it to not scratch anything, bike had less than 20 miles on it then lol. Haven't tried since. Is it safe to leave it on a headstand with the suspension uncompressed for an extended period of time?....prob 8-10months? If not I'll just throw an old tire on it during that time and leave it just on the rear stand. Thanks
I leave mine on the stand during the cold months. Granted that is not 8-10 (deployment?). The stand is the same, the pins are different from bike to bike.
phatplat is offline
The Following User Says Thank You to phatplat For This Useful Post:
VK56DEHAN (06-08-15)
post #22 of 27 Old 06-08-15, 11:14
TBSS
It won't hurt to leave the forks hanging, it is better than leaving a load on the springs.
You may need different pins if you use it on different bikes but they are under $10.
TBSS is offline
The Following User Says Thank You to TBSS For This Useful Post:
post #23 of 27 Old 06-08-15, 18:05
MadMel
MadMel's Avatar
The Anderson stand comes with 7 different pins.
MadMel is offline
post #24 of 27 Old 10-11-15, 02:15
VK56DEHAN
VK56DEHAN's Avatar
Originally Posted by D675R newby View Post
I have a 13 tona and use a Pitbull headlift stand. Super close to the dampener but does not hit.
So I finally ordered the pitbull head lift stand off revzilla for $190. Little expensive but it'll get used for a long time so I'm sure money well spent. Pit bulls site said the 13+ Daytona used the 26S pin I just want to confirm that is the correct one from other owners. There seemed to be a lot of reviews from people with different bikes stating the pin chart was incorrect for a few of them. Thanks
VK56DEHAN is offline
post #25 of 27 Old 10-11-15, 03:54
D675R newby
D675R newby's Avatar
Im using the 26s pin with no issues. It looks like the dampener is in the way but there is enough play that you can move it out of the way.
If it doesn't fit force it, if it breaks it needs replaced anyway.
D675R newby is offline
post #26 of 27 Old 10-11-15, 11:48
VK56DEHAN
VK56DEHAN's Avatar
Awesome thank you
post #27 of 27 Old 10-15-15, 13:47
VK56DEHAN
VK56DEHAN's Avatar
Got my stand in today and went to lift the bike.....everything is so close but it fits. Very good quality stand id highly recommend it. Just make sure to flip the nut on the pin hardware so it doesn't make contact with the damper. Also make sure the wheel is straight as that will also cause it to make contact with the damper. Thanks for the suggestions everyone.
