Hi all Iím in need of help/opinions! - Page 2 - Triumph675.Net Forums
post #11 of 19 Old 07-01-18, 11:43 Thread Starter
Cosmic1000
Notice the loom next to the plug, that loom comes off the back of the servo motor! I think the carbon canister is U.S spec only for emissions etc, donít think uk bikes have them! Has anyone got any idea where the servo motor actually plugs into? Or is part of the main loom?
Sent from my iPhone using Tapatalk Pro
Cosmic1000 is offline
post #12 of 19 Old 07-01-18, 12:11
Cheyenne Bodie
Cheyenne Bodie's Avatar
I don't think I showed you a matching plug, but it's from a cable grouped up with my servo motor wiring and goes to the line which feeds the canister. If you don't have the canister box itself you may still have lines and regulation going on under there just in a different way, but I don't know.
Cheyenne Bodie is offline
post #13 of 19 Old 07-01-18, 13:17
Verichai
Verichai's Avatar
So what would the symptoms be if the valve was not functioning properly? Power decrease, I assume? Any telltales that it's not functioning? I bought my 2012 from the original owner and it had been several years since I last rode a (2006) Daytona, so my basis for comparison is fuzzy. I do notice this weird clattering sound immediately after start up, but it goes away after a couple seconds.
Verichai is offline
post #14 of 19 Old 07-01-18, 13:28 Thread Starter
Cosmic1000
From what Iíve read they have a habit of failing closed, so in fairness if it had failed closed it would restrict the exhaust so Iíd imagine yes youíd lose power mate
post #15 of 19 Old 07-01-18, 13:40
Verichai
Verichai's Avatar
That's what I thought, too. But I was curious to know if there is a way to know for sure if it is working properly? Is there a change in exhaust sound, power delivery, ect when the valve changes position?
Verichai is offline
post #16 of 19 Old 07-01-18, 14:08 Thread Starter
Cosmic1000
Does anyone know which way is open and which way is closed? I assume itís possible to just lock wire the valve open?
post #17 of 19 Old 07-01-18, 15:11
Cheyenne Bodie
Yea, it will make the exhaust much louder under 6K RPM, it's designed to open above 6K normally. If your bike is clattering it might be the rock in your cat converter, but it's hard to say for sure. When it's not working the bike will be down on power, uneven with delivery, and basically fuunction fine but ride like crap.
The valve's default state is open, removing the cables (given the valve is functioning) will leave the valve open all the time. Some people have wired them open to be sure.
This thread shows the open valve after cable removal, and outlines how to do the removal properly: https://www.triumph675.net/forum/showthread.php?t=43487
post #18 of 19 Old 07-01-18, 15:15 Thread Starter
Cosmic1000
I just think mine seems down on power, are there any other common issues that can result in power loss? Or perhaps itís because my last bike was a K5 GSXR 1000! The triumph just doesnít seem to come alive until higher in the Rev range yet everyone says itís low down grunt is superb?
post #19 of 19 Old 07-01-18, 15:54
Cheyenne Bodie
Everything from the tune/mis-tune to the air filter could cause a loss in power. Injectors being gunked up, lower quality fuel, natural engine wear, cat converter being faulty, etc...so many things which wouldn't outright throw a code. If you could check compression and do service tests on sensors and other devices that would rule out a ton of stuff, all stuff you can do with just checking data from the ECU. If you have a code then the code is probably the source of any problems, though there could be others conceivably. Specific to the 675 there's nothing I can think of worth mentioning.
If your EXUP is deleted you'll have much less low-end torque, it moves it higher in the rev range is all. It might make more HP up top as well, but down low it turns it into a bit of a prissy little Nancy. With the EXUP it's not exactly gobs of TQ, but it's enough to be useful for putting around town. Compared to a Gixxer1000 it should be able to reasonably keep up from 30-100 mph, but it depends on gearing I suppose. It's really more about power to weight than outright power, but the Suzuki should still certainly be more beastly all around.
