Wheel bearing sizes - Triumph675.Net Forums
post #1 of 3 Old 05-06-18, 22:39 Thread Starter
bluedaytona02
bluedaytona02's Avatar
Wheel bearing sizes
Thought this might be helpful
Front wheel -
Bearing 20 x 42 x 12 sealed (x2)
Seal 30 x 42 x 6 (x2)
Rear wheel & sprocket carrier -
Bearing 20 x 47 x 14 sealed (x2)
Bearing 25 x 52 x 15 sealed
Seal 30 x 42 x 7
Seal 30 x 47 x 6
Seal 35 x 52 x 6
I used a Balls kit to get sizes for the rear and took the OEM ones from the front into the local (after fitting a Balls kit).
My local didnt have the 6mm thick seals on the shelf but instead supplied them in 7mm which makes no difference except they may sit a little higher than the bearing recess.
Attached in my invoice in AU$.
Sent from my SM-G930F using Tapatalk
Current: '06 Daytona 675 ('08 BEARS winning bike - Chris Panayi) White with Pitty's Custom Vinyls TTC decals STM Slipper Clutch Braking wave rotors with folding/adjustable levers GB engine covers Valter Moto Rearsets Race kit detent wheel & idle adjuster 1050 throttle tube Captive Wheel Spacers MotoGems bling Vortex clip-ons, Stomp grip 520 conversion Puig screen Madaz slip-on Intake flapper & Ex-up removed Swing-arm pivot mod. Thinner head gasket Custom tune
bluedaytona02 is offline
post #2 of 3 Old 05-07-18, 23:05
Shamrock
Mean Green Mod
Shamrock's Avatar
For what bike, and year?
I ask, because my 2014 Daytona calls for:
Front...20id x 42od 12w (2 required) (T3800702)
Rear...20id x 47od x 14w (2 required) (T3800703)
25id x 52od x 15w (1 required) (T3800029)
Shamrock is offline
post #3 of 3 Old 05-07-18, 23:31 Thread Starter
bluedaytona02
First and second gen Daytona and Street.
