2011 D675 Down Shift Issue - Page 3 - Triumph675.Net Forums
post #21 of 33 Old 04-19-19, 22:03
cdenley
Originally Posted by MadMel View Post
My bike is dyno tuned, making 125 hp & 54 ft-lbs on that particular dyno. No issues with the stock springs for me.
Glad to hear that. Mine only made 120 hp & 53 ft-lbs with the Arrow system and pump fuel. Need to get it tuned for the Akra system now. I've been using the STM slipper with diaphragm springs.
Chris Denley
CCS Midwest Amateur #212
fb.me/DenleyRacing
cdenley is offline
post #22 of 33 Old 04-19-19, 22:17
MadMel
MadMel's Avatar
The only power mods on my bike are an Akra full system and a MWR race air filter. Of course, outright HP numbers need to be taken with a grain of salt, every dyno is different. Relative numbers though... hope you see a good bump with your new tune.
MadMel is offline
post #23 of 33 Old 04-20-19, 08:00 Thread Starter
apiazza
apiazza's Avatar
@apiazza Turns out that I not only saved the manual to Google Drive, but I also PDFed a how-to thread from this forum so I could print it out for when I did the job.
https://drive.google.com/file/d/0Bz9...w?usp=drivesdk
Awesome. Thank you. I just sent a request for the docs.
I did see the mention of stiffer springs from what yoyo sent me last night. I'll stick with stock. Parts and tools are ordered. Might have some time next weekend to tackle. First thing is to pull a couple parts out of spare blown up engine.
Sent from my SM-G965U using Tapatalk
apiazza is offline
post #24 of 33 Old 04-20-19, 16:26
MadMel
MadMel's Avatar
Oops, I forgot to allow sharing with a link. Fixed now, anyone should be able to download.
MadMel is offline
post #25 of 33 Old 04-20-19, 16:33
MadMel
MadMel's Avatar
Found the original post that I PDFed, it's really good.
https://www.triumph675.net/forum/sho...1#/topics/5191
MadMel is offline
The Following User Says Thank You to MadMel For This Useful Post:
apiazza (04-20-19)
post #26 of 33 Old 04-20-19, 16:34 Thread Starter
apiazza
apiazza's Avatar
Just looking for some clarification here. To get to the detent wheel and shift mechanism. I will need to remove the outer basket. Does it basically just wiggle out? I know it engages with the oil pump on the back side. I guess it just slides off the bearing.
apiazza is offline
post #27 of 33 Old 04-20-19, 17:03
MadMel
MadMel's Avatar
Sorry, did mine in 2013, and I can't remember what I had for breakfast.
MadMel is offline
post #28 of 33 Old 04-21-19, 16:54 Thread Starter
apiazza
apiazza's Avatar
No problem. These questions might be better pointed towards @MacBandit .
In addition to that questions, how do I safely remove the detent wheel from the drum? I pulled the shift mechanism and detent arm out of the donor motor and wanted to pull the wheel as "practice" but I dont want to damage anything in the process of prying it away from the drum. Thanks for all the help, guys! I'm feeling more confident once all the parts show up to complete the job.
apiazza is offline
post #29 of 33 Old 04-23-19, 16:56 Thread Starter
apiazza
apiazza's Avatar
The factory pro shift star instructions say you can pull the star off with pliers but I can't seem to get it to budge. I dont want to pry against the drum bearing. Any ideas?
apiazza is offline
post #30 of 33 Old 04-23-19, 17:55
MadMel
MadMel's Avatar
I don't know if there's enough space, but could you get a bearing puller in there?
MadMel is offline
