Bypassing clutch/starter switch, while still having use of quick shifter - Triumph675.Net Forums
post #1 of 18 Old 04-05-19, 15:58 Thread Starter
TrampusP International
I did some searching and haven't found what I'm looking for. Does anybody know of a way I can bypass the clutch switch but still have use of the quick shifter? I've been wary about taking the button/switch off the end of the cables and splicing them together.
I know one can bypass the clutch switch by removing it from the perch (I've done that), but then the quick shifter is of no use, since that same switch tells the quick shifter the clutch is engaged/disengaged.
Side note - I'd prefer to not go back to the stock clutch, as my upcoming setup relies on a short clutch.
TrampusP International is offline
post #2 of 18 Old 04-05-19, 20:07
bill_yyy
Most simple thing to do would be just wire in an on/off toggle switch for the clutch switch.
bill_yyy is offline
post #3 of 18 Old 04-06-19, 09:40
Yes a momentary toggle switch is what you need.
On another note I have short levers with the stock clutch perch.
MacBandit is offline
post #4 of 18 Old 04-09-19, 14:30
hzhong456
I bought a damaged switch assembly from eBay and de-pinned all the wires except for the clutch switch wires. It leaves you with a stock clutch switch on a stock harness plug.
hzhong456 is offline
post #5 of 18 Old 04-14-19, 02:25 Thread Starter
Can you explain this in more detail? Perhaps itís because itís late, but Iím slightly confused .
post #6 of 18 Old 04-14-19, 02:27 Thread Starter
Was thinking about trying to get a momentary switch working.
I got an easy pull clutch, so the stock perch is a no go.
post #7 of 18 Old 04-14-19, 07:12
UK_Race_Support
UK_Race_Support's Avatar
We do a replacement clutch lever with perch and switch assembly and a choice of long or short lever. Failing that we also do small handle bar switches which can be momentary or latched.
https://www.ukracesupport.com/collec...-clutch-levers
https://www.ukracesupport.com/collec...-left-or-right
UK_Race_Support is offline
post #8 of 18 Old 04-14-19, 19:10
hzhong456
Originally Posted by TrampusP International View Post
Can you explain this in more detail? Perhaps it’s because it’s late, but I’m slightly confused .
The left handlebar switch pod and the clutch switch are combined into one plug. I just bought a spare switch pod that included the clutch switch (sometimes people cut it off) and removed all the wires from the plug side except for the 2 needed for the clutch switch.
I found a broken OEM switch pod with complete clutch switch on eBay for about 20 shipped. The ones for the same year street triples will also work.
post #9 of 18 Old 06-06-19, 10:55 Thread Starter
Do you have a picture of what youíre talking about?
post #10 of 18 Old 06-11-19, 16:32
tim8061
The Triumph QS works if you don't pull the clutch, and is disabled when you pull the clutch. So remove the switch and wire the harness as if the clutch is not pulled.
tim8061 is offline
