did I murder my baby? - Page 2 - Triumph675.Net Forums
post #11 of 64 Old 05-12-13, 18:40 Thread Starter
Rachel Cravens
Rachel Cravens's Avatar
yeah its at riverside. The sounds do sound like a chain banging around inside... could the engine be totalled if the pistons have banged into the valves?
Rachel Cravens is offline
post #12 of 64 Old 05-12-13, 18:46
timwu12
timwu12's Avatar
Not necessarily. The head will definitely need to be re-worked if the valves got bent from the piston slamming into it. Depending on the force, the pistons itself may need replacing if there's a love stamp left behind from an opening valve, but you'd have to pull the head to find that out.
Also, was there a particular RPM that the tapping noise became more apparent? Say while riding at 6-8k RPM, or was it constantly there at around the same volume at all RPMs?
timwu12 is offline
post #13 of 64 Old 05-12-13, 18:47
R8td-R
R8td-R's Avatar
hope thats not the case
R8td-R is offline
post #14 of 64 Old 05-12-13, 18:47
TwoWheeledWonder
Noob Hazer
TwoWheeledWonder's Avatar
So you did an oil change and then the engine went... Did you just put in 3.3 and then call it good or did you actually check the levels?
Could be many things, I am betting CC with the sounds you are describing, but hard to say, the shop will be able to find out and hopefully you will get everything replaced under warranty if you still have it.
2010 TornadoRed D675 Trackbike
TwoWheeledWonder is offline
post #15 of 64 Old 05-12-13, 18:49
TwoWheeledWonder
Noob Hazer
Yeah, either way sounds like that shop has a bit of work ahead of it haha
post #16 of 64 Old 05-12-13, 18:55 Thread Starter
Rachel Cravens
it happened at low rpms, just moving around town so like 1st 2nd gear, and was at random intervals. and yes, of course i checked the oil levels! ;)
post #17 of 64 Old 05-12-13, 18:56
TwoWheeledWonder
Noob Hazer
Then it just sounds like you were one of the unlucky of a mass produced product. Hopefully your shop has some quality techs and they get this shit fixed soon.
post #18 of 64 Old 05-12-13, 18:59
R8td-R
R8td-R's Avatar
what kind of tensioner do they have? hydraulic or mechanical ones?
was there a year range that was prone to having that issue?
R8td-R is offline
post #19 of 64 Old 05-12-13, 19:02 Thread Starter
Rachel Cravens
dunno, thats tech stuff... It's good to have something to wrap my head around at least. even if its bad news, thanks for the advice everyone hopefully ill be riding soon!
post #20 of 64 Old 05-12-13, 19:06
timwu12
timwu12's Avatar
The OEM tensioners use a spring tensioner. Many have replaced the OEM ones for the APE manual tensioners.
This was a huge problem for gen 1 bikes (06-08), I don't have a 2nd generation bike, but I don't believe the 2nd generation bikes fixed this issue, so it's probably safe to assume that they all suffer from this.
However, if you use the Triumph kit tensioner, it'll solve that problem since it uses a stiffer spring, but it costs 2x as much as a manual tensioner.
timwu12 is offline
