replacing bar ends - Triumph675.Net Forums
post #1 of 5 Old 03-02-16, 23:05 Thread Starter
DOUGFUNNIE17
replacing bar ends
well i replaced my handle bar grip and trying to replace the bar ends as well but i can't take them off,any one has done this i need help pls thanks
Name:	bar end .jpg
DOUGFUNNIE17 is offline
post #2 of 5 Old 03-02-16, 23:17
ALLoneUP
ALLoneUP's Avatar
Use the search function. There are multiple step by step instruction threads with pics and videos.
ALLoneUP is offline
post #3 of 5 Old 03-03-16, 00:36 Thread Starter
DOUGFUNNIE17
searched but none actually have, how to replace the bar end? I'm trying to take off the allen screw off it so i can replace it or what to do i need to actually replace it with ?
post #4 of 5 Old 03-03-16, 07:38
Dismalrain770
Dismalrain770's Avatar
You need to use a strap wrench to hold the bar end in place and take the allen bolt out. My bolts got stripped out and I ended up having to drill one of them out. The bolt is a M5 .8x35mm if you need to replace it, I found philips head replacements at Home Depot.
Dismalrain770 is offline
post #5 of 5 Old 03-03-16, 11:45
ALLoneUP
ALLoneUP's Avatar
Here you go:
https://www.triumph675.net/forum/showthread.php?t=14181
ALLoneUP is offline
