Improving Shift Quality - Page 2 - Triumph675.Net Forums
post #11 of 27 Old 08-20-15, 11:39 Thread Starter
huras
Thanks everyone. Those are some good ideas. Are there any bushings in the shift linkage that could be worn out?
huras is offline
post #12 of 27 Old 08-20-15, 12:23
airrix
airrix's Avatar
Originally Posted by jdgun_13 View Post
IN back to back testing the shift spindle has made the shifting not as smooth,requiring more effort & harder to find neutral and i have hit more false neutrals since i installed it.
My bike has never had a smooth shifting transmission since I bought it... from using stock rearsets, to using attack rearsets, with or without the shift spindle.
My 2006 Daytona & 2012 675R both were smoother in every aspect, from stock to using attack rearsets.
I just installed my Sato spindle holder on my 2012 STR and rode almost 300 miles with it now. I using the Triumph quick shifter and Daytona rearset. To be honest, it didn't make my shifting any smoother (I'm thinking this is more of a transmission behavior. With that said, it did make my gear selection more solid/positive - most of the slack from the shifter was gone. I haven't had any false gearing yet.
airrix is offline
post #13 of 27 Old 08-20-15, 18:24
topgunz1
I've only got about 120 miles with mine installed, but it definitely feels better. "more positive" is about as good as I can describe it as well, it takes any vague feeling out and it just feels almost like an on/off switch, Yes in gear, No it isn't.
I use Triumph quickshifter and stock rearsets. 8K miles on a 2012.
“Faster, Faster, until the thrill of speed overcomes the fear of death.”
― Hunter S. Thompson
topgunz1 is offline
post #14 of 27 Old 08-20-15, 19:22
Glocken
Glocken's Avatar
@airrix @topgunz1 that's the whole point of the spindle holder. it's suppose to give you a more positive gear engagment; it has nothing to do with smoother, smoother would be on yourself and the oil you use.
Elka 3 way shock|Penske fork valves|Leo full titanium & CF|Hyperpro steering damper|GB frame slider & engine casings|Cyclecat clipons|Pazzos|ZG|Proton|CF tank sliders|Dave Moss Techspecs|Evo Tech Sharkfin|Sato Shift Spindle holder
Glocken is offline
post #15 of 27 Old 08-23-15, 14:00
vitogt2
missing shifts is not cool. make sure you are using good oil and your shift linkages are not loose.
vitogt2 is offline
post #16 of 27 Old 08-24-15, 21:17 Thread Starter
huras
Does anyone know if there are bushings in the linkage that are replaceable?
huras is offline
post #17 of 27 Old 08-24-15, 22:38
No replaceable bushings. All the pivot points should be dissasembled occasionally and cleaned and greased.
post #18 of 27 Old 08-26-15, 21:57
Superhawk
Superhawk's Avatar
Like he said...
Originally Posted by Glocken View Post
Sato shift spindle holder. Preload your shifter. Kick it harder. Change the oil.
Ditto above...
Know God; Know Peace
Kevin/34: "I pull that chin strap tight - We're on a racetrack. We're out here riding motorcycles. You put your helmet on, you pull that chin strap tight, there should be nothing but a smile on your face. Because what the hell else would you rather be doing?"
Superhawk is offline
post #19 of 27 Old 08-28-15, 15:43
Punisher14
Shift spindle did nothing but improved the shifting. there is no way stiffening the shift spindle is going to degrade this adding the chance false neutrals or making it harder to find neutral it only improves on all of that. Im not certain, but these people might want to look into their abilities before blaming this product
Punisher14 is offline
post #20 of 27 Old 08-28-15, 16:12
cjwwd2
cjwwd2's Avatar
Has anyone used the Triumph aftermarket shift spindles?
cjwwd2 is offline
