Keyless ignition with steering lock - Triumph675.Net Forums
post #1 of 3 Old 05-08-19, 11:14 Thread Starter
Glocken
Glocken's Avatar
Has anyone done keyless ignition while maintaining the steering lock function?
All the people that do it end up removing the ignition barrel, I want to still have steering lock
If so can someone pm me how they did it or a link to how to do it.
Elka 3 way shock|Penske fork valves|Leo full titanium & CF|Hyperpro steering damper|GB frame slider & engine casings|Cyclecat clipons|Pazzos|ZG|Proton|CF tank sliders|Dave Moss Techspecs|Evo Tech Sharkfin|Sato Shift Spindle holder
Glocken is offline
post #2 of 3 Old 05-08-19, 17:36
MadMel
MadMel's Avatar
I'm thinking that you could just install a Woodcraft keyless ignition, and leave the ignition assembly in place. I have the Woodcraft, it's plug and play.
https://www.woodcraft-cfm.com/produc...rness-assembly
If you went that route, Eric at Woodcraft would be happy to answer questions and confirm that it'll work.
MadMel is offline
The Following User Says Thank You to MadMel For This Useful Post:
Glocken (05-09-19)
post #3 of 3 Old 05-08-19, 17:48
Kevin7909
As mentioned by MadMel, you can use the woodcraft unit to start the bike. The locking mechanism is purely mechanical so you have a choice. Either leave the one that's on there now and zip tie the cables so they are out of the way(but still appear to function to the casual onlooker), or purchase another ignition unit with a key and remove the harness so you can go back to OEM if desired.
Kevin7909 is offline
The Following User Says Thank You to Kevin7909 For This Useful Post:
Glocken (05-09-19)
