Gen1 Street Triple / Daytona Massive Sale of Accessories, Parts and Tools - Triumph675.Net Forums
Parts Sell, trade or give away your parts here. FS, WTT, FF all welcome.
post #1 of 11 Old 08-04-19, 14:46 Thread Starter
Aprilian
Aprilian's Avatar
Updated - Gen1 Street Triple / Daytona Massive Sale of Accessories, Parts and Tools
After 9 years with my 2010 Street triple R I decided it was time to try something dramatically different... a 2019 Street Triple RS!
All parts are crash, drop and damage free unless noted and when possible include the instructions. Anything with more than expected wear and tear for used parts will be noted.
Many of these items fit that same generation Daytona and other years/generations of this bike. Please confirm fitment to anything other than a 2010 Street Triple R before buying. I will only take [B]returns[B/] if I accidentally grossly misrepresented the item. If that happens, I will reimburse shipping too (provided shipping wasn’t more than the parts).
Shipping is at actual cost and will be via USPS flat rate boxes - except for the very large items. Shipping will be after the funds clear.
Prices - generally are 50% of new. SPF = Sold Pending Funds clearing my bank.
Please email me at ellis dot ian dot h @ gmail dot commmmmmmmmmmmmmm with questions and what you want to buy.
Thanks for looking!
New OEM parts
Fuel line $25
Air box seal $10
shifter rubber $5
Bar end screws (2) $2
New non-OEM parts
Motion Pro grip set $5 Sold
K&N oil filter - not one of the recalled ones $5 Sold
Used tools
Wiseco valve shim kit $40 Sold
Used OEM parts
Anodized front and rear brake reservoirs $90 SOLD
Hydraulic Cam Chain Tensioner - taken off at 1k miles $10
Street Triple Cams $40
OEM front sprocket (?is OEM 525?) $5
Front brake lever (R model) $25
Used non-OEM parts
Pazzo fork preload adjusters $22
Supersprox 49t 520 $30
Pit bull 45t 520 $25
OEM throttle housing and cable set $70
Eliptech aFlasher alarm simulator and turn signal reminder $30
Carbon fiber swingarm covers painted flat black - paint at heels has worn off. You will need new double-sided tape and can run them as-is, repaint or sand down and return to exposed CF $55
Magnetic drain plug drilled for safety wire $5
Odds and Ends
OEM Headlight wiring harnesses (2) - $2
Box of miscellaneous bolts connectors etc.
Bag of turn signal parts $10
Stock header with black Jet Hot coating - one scratch on bottom $100
Stock mufflers and heat shields with black Jet Hot coating $200
Stock mufflers with heat shields $75
Angry eyes round headlight covers - don’t use with headlight bulbs on, too much heat $5
Four fork springs 2 OEM - one .85 RaceTech and one .95 racetech $55
Hyperpro spring for a Penske shock ?? rate $10
Penske misc shock parts including Torrington adjustment bearing $10
Six rubber Triumph patches from tank bags $5
End of list…. There has to be SOMETHING you can’t live without ;-)
Ian
"I used to get upset, but now I'm just amused!" Elvis Costello
Last edited by Aprilian; 06-12-20 at 23:28. Reason: updated sold items - removed sold items
Aprilian is offline
post #2 of 11 Old 08-05-19, 22:55 Thread Starter
Aprilian
Aprilian's Avatar
More photos
Ian
Last edited by Aprilian; 08-17-19 at 17:47. Reason: updated sold items - removed photos of sold items
Aprilian is offline
post #3 of 11 Old 08-06-19, 00:46
Rookie28
Rookie28's Avatar
Email sent!
Rookie28 is offline
post #4 of 11 Old 08-06-19, 22:41 Thread Starter
Aprilian
Aprilian's Avatar
All emails and PMs replied too. Lots of good stuff still available.
Ian
Aprilian is offline
post #5 of 11 Old 08-09-19, 16:36
dis_dis
dis_dis's Avatar
ill take the woodcraft covers if still available, pm incoming
dis_dis is offline
post #6 of 11 Old 08-09-19, 18:10 Thread Starter
Aprilian
Aprilian's Avatar
PM replied to and list updated
Ian
Aprilian is offline
post #7 of 11 Old 08-17-19, 17:48 Thread Starter
Aprilian
Aprilian's Avatar
I updated sold items - removed photos of sold items - lots of good parts still available.
Ian
Aprilian is offline
post #8 of 11 Old 05-10-20, 15:50 Thread Starter
Aprilian
Aprilian's Avatar
Original post updated with items still available.
Ian
Aprilian is offline
post #9 of 11 Old 09-24-20, 21:09
khr
khr's Avatar
Whatís in the box of turn signal parts? Iím interested.
khr is offline
post #10 of 11 Old 09-25-20, 10:47 Thread Starter
Aprilian
Aprilian's Avatar
I have misplaced the turn indicators, but still have the box of miscellaneous parts. Are you looking for anything in particular?
it includes heel guards, shifter rod, spring camchain tightener, and lots of other take off bits.
Ian
Aprilian is offline
You may not post new threads
You may not post replies
