HOW TO: Chain Adjustment - Page 9 - Triumph675.Net Forums
post #81 of 86 Old 07-11-17, 23:11
Bamboo671
Bamboo671's Avatar
I've always done it in gear buy that's just me. It helps with it not rolling.
Bamboo671 is offline
post #82 of 86 Old 06-02-19, 06:05
OzMoto
OzMoto's Avatar
How do you roll the wheel to find the tightest spot to adjust the chain if it is in gear? ;)
Ride carefully - You are invisible.
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R | SC-Project CF Oval Silencers | Triumph Quickshifter | 520 Conversion (-1 front)
RIP: 2003 CBR600RR
Sold: 2012 CBR250R | 2000 NSR150SP
OzMoto is offline
post #83 of 86 Old 06-02-19, 14:50
siq75
Originally Posted by Neanderthal View Post
At the end of the day, just maintain decent slack (on the loose side) and keep the chain clean and there's no reason to not get 25,000 or more miles out of a chain. I got about 30,000 out of my last chain and it was just starting to stretch. Just maintained slack and clean (kerosene) & lube (DuPont Chain Saver or Wax). If you keep it clean & lubed, you will rarely have to adjust it.
I fully agree with everything you are saying. My original chain has 23,000 miles on it, and I use the kerosene/DuPont Chain Saver method. I make ZERO chain adjustments between tire changes.
Pull in the clutch!
Daytona 675 TRIPLE SE
siq75 is offline
post #84 of 86 Old 06-23-19, 01:48
OzMoto
OzMoto's Avatar
Originally Posted by siq75 View Post
Pull in the clutch!
Haha touché. I wasn't even thinking about it. I've always thrown mine up on a stand.
What a brainfart.
RIP: 2003 CBR600RR
OzMoto is offline
post #85 of 86 Old 06-23-19, 22:56
andy_tt
I do 1.5 inch max slack for the chain (as per Dave Moss) and Ligthtech chain adjusters (came with the bike :)) to make sure both sides are aligned.
andy_tt is offline
post #86 of 86 Old 06-24-19, 08:23
OzMoto
OzMoto's Avatar
I go by the service manual, usually err on the looser side which says: The vertical movement of the drive chain must be in the range of 20 to 30 mm.
My original manual says 13mm - 32mm. I have mine set ~25-28mm.
OzMoto is offline
