Triumph is replacing all old R/R units with the new Mosfet free of charge - Page 9 - Triumph675.Net Forums
post #81 of 84 Old 07-14-15, 22:03
nyboy
nyboy's Avatar
ah ok, thanks for the info
nyboy is offline
post #82 of 84 Old 07-15-15, 03:41
e_cape007
e_cape007's Avatar
Thanks for the useful info Ruby Racing - I will try Triumph UK.
I checked the R/R, because I had a charging problem at the end of June, and it is the old type. It is, following the excellent diagnostic guide in this Forum, fully functional however. I checked the stator, and all three outputs were shorted to engine ground - pulled the cover to find two windings blackened.
Plenty of aftermarket stators available on E-Bay, but when postage is added in and then customs duty it started to look scary. On the advice of another biker, who restores old machines, I took the stator to a local armature rewinder and they repaired it for me. Slightly more than the cheapest aftermarket one on E-Bay, but no postage or duty so a relative bargain. Also fixed in two days (was stripped, sand-blasted, powder-coated and re-wound, most by hand as it was [for them] a non-standard part).
All back together, and battery voltage at idle is 14.2V
So far, so good, now it's a case of seeing if the system lasts!
I've attached before and after pics of the stator, the damage is far less extensive than others I've seen on the Forum.
Name:	Daytona Stator, before.jpg
ID:	173026   Click image for larger version
Name:	Daytona Stator, after.jpg
e_cape007 is offline
post #83 of 84 Old 07-15-15, 04:30
Ruby Racing
Ruby Racing's Avatar
Happy to help and glad you have things sorted.
Ruby Racing is offline
post #84 of 84 Old 09-02-18, 17:14
Travis14
You the man!
Thank you so much for posting this. You just saved me so much money.
Travis14 is offline
