How does one get to the 30A fuse? - Page 2 - Triumph675.Net Forums
post #11 of 16 Old 01-25-11, 19:18 Thread Starter
eldy
Well... I did as MacBandit did and removed the tank rear pivot bolt and got to the fuse. Only thing is that it wasn't blown. I checked for exposed wire and all the wiring harness connections and everything seems okay. What should I check next and how?
eldy is offline
post #12 of 16 Old 01-25-11, 21:42
Karl
Karl's Avatar
I hate to say this but, is the kill switch on?
Karl is offline
post #13 of 16 Old 01-26-11, 00:10 Thread Starter
eldy
The kill switch is in the "run" position.
eldy is offline
post #14 of 16 Old 01-26-11, 00:27
Karl
Karl's Avatar
Just had to checkÖ No offence but Iíve done it my self.
Karl is offline
post #15 of 16 Old 01-26-11, 23:42 Thread Starter
eldy
The power problem has been resolved. The battery was the culprit. It was showing 13.0V on a multimeter without a load and only a month and a half old.
A friend came over and hooked up the bike to a known healthy battery and all is well.
If you have a similar problem, try using a known healthy battery before you start unplugging and checking the electrical harnesses for continuity and short circuits.
Keywords: no power cut out electrical fuse suddenly die
eldy is offline
post #16 of 16 Old 06-11-19, 21:35
Quinton Couch
I lifted the tank but cannot find the fuse. Triumph Thruxton. What exactly am I looking for? Pictures appreciated.
Quinton Couch is offline
