Wheels Bearing removal - Triumph675.Net Forums
post #1 of 2 Old 04-24-18, 05:57 Thread Starter
Safety
Safety's Avatar
Question Wheels Bearing removal
Hi,
I am planning on replacing the wheel bearings on my 2014 Street Triple R.
Should I plan on ordering the Triumph extraction kit T3880053 for that matter, it's around 35$ on-line,
https://www.bikebandit.com/oem-parts...80053/b1568975
From what I read on another post is that Euro's bearings assembly can be tricky to pull out of the wheel and I am looking for the best/easiest way to do it.
Also, if anyone is in the vascinity of Montreal Quebec in Canada, where do you folks order or get your replacements bearing from? Aside from the genuine Triumph dealers I haven't found any bearings available on populars Canadian's on-line stores.
Thanks for taking the read my post,
Be safe out-there,
"The difference between stupidity and genius is that genius has its limits"
Albert Einstein
~ Safety
Safety is offline
post #2 of 2 Old 04-26-18, 12:27 Thread Starter
Safety
Safety's Avatar
So dealer remains an options ;)
Some Quebec's racing resellers - like Pete's Super bikes can get those for you.
I also found the following site in the USA that ships to Canada as well.
https://www.petes-superbike.com/index.php?language=en
For the bearing removal there are other threads around here and a lot of youtube videos for that matter.
Thanks,
Albert Einstein
~ Safety
Safety is offline
Tags
bearing removal , street triple
