2016 D675 clutch safety switch removal - Triumph675.Net Forums
post #1 of 4 Old 06-07-18, 18:49 Thread Starter
Backho
Hello all,
New to the forum and Triumphs. I'm converting to a track only bike. Question; can I just jumper out the clutch safety switch without affecting the ECU on the 2016 Daytona 675? Many thanks!
Backho is offline
post #2 of 4 Old 06-08-18, 00:07
No. It has to be a closed circuit for startup but then open when you’re moving. You could put a momentary toggle switch on it.
post #3 of 4 Old 06-09-18, 11:26 Thread Starter
Backho
Thank you for your response. I know that on a Suzuki, removal of the safety clutch switch affects the ECU and/or map. Just to be safe I'm going to leave that portion of the wiring loom intact. Anxious to thrash it's guts out at the track!
Backho is offline
post #4 of 4 Old 06-09-18, 11:54
Triumph and Suzuki use the same ECU and the same base software. Triumph just has a custom interface and mapping on top of that.
Tags
clutch switch , ecu
