Header gasket direction - Triumph675.Net Forums
post #1 of 3 Old 09-28-20, 21:08 Thread Starter
jollyrog3r88
jollyrog3r88's Avatar
I have hopefully a simple question, but have not found it via search.
When replacing the header gasket (copper crush), what direction faces the front? Do the little tabs go on the outside (facing the front wheel), or on the back? Or am I overthinking it and makes no difference.
Also, are there any best practices or recommendations for sealing the joints of the exhaust back together again (putting on a new system). I've read about people using grease or silicon to avoid leaks.
Thanks!
jollyrog3r88 is offline
post #2 of 3 Old 09-29-20, 00:04
ramnakhle
ramnakhle's Avatar
Just checked the manual
It says the face of the gasket with the tab should be toward the cylinder head.
If you’re not already aware, there’s a specific tightening sequence AND torquing procedure to the exhaust studs.
Be careful doing that
ramnakhle is offline
The Following User Says Thank You to ramnakhle For This Useful Post:
jollyrog3r88 (09-29-20)
post #3 of 3 Old 09-29-20, 07:20 Thread Starter
jollyrog3r88
Thanks for that - I did not see it in the manual that I am using.
I am aware of the tightening sequence, so hopefully no issues with that!
