Triumph675.Net Forums
Triumph675.Net Forums (https://www.triumph675.net/forum/index.php)
-   General 675 discussion (https://www.triumph675.net/forum/forumdisplay.php?f=10)
-   -   Parking light issues (https://www.triumph675.net/forum/showthread.php?t=238698)
Magnum Maximum 10-27-17 16:31
I've searched for this issue and wasn't able to find anything. As of this morning, the parking light is not staying on and flutters frequently (sporadic flashing). Could it be a loose connection, loose fuse, moisture from the elements getting into the connectors? Bike barely has 2,500 miles on it. Bought it brand new in early September of this year.
iadminko 10-27-17 16:39
I suppose it should be under warranty, so it is better to go to the dealer service.
Darkness14 10-31-17 16:27
Be careful not to use the parking function a lot. It will own your battery and you will be left stranded. Happened to me twice when i first got my bike. Had no clue that was a function. You should have seen me trying to trouble shoot as I was pissed off as hell trying to figure out why my battery kept dying
Magnum Maximum 11-01-17 22:11
5 Attachment(s)
Was able to resolve the issue. The bulb blew out. Replaced it with an amber LED. New problem now. I lost one of those rubber nuts that the screws for the wind screen go into. It must've popped off when I reinstalles the windscreen and wasn't aligned properly. I have no clue where it went to. Could I just use a regular nut, or do I need to use that specific part?
EDIT: They're called rubber rawl well nuts.
MachOne 11-07-17 07:42
Cheap LEDs don't last well in that light. Too much heat build up. I got fed up of changing them every other week, sucked it up and paid 20 dollars for a Sylvania 194 LED. No issue in 3 months. It has it's own current limiting resister and heat dissipation all in the 194 package
Sent from my Pixel XL using Tapatalk
Magnum Maximum 11-08-17 14:25
I believe these were Sylvania as well.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
