Triumph675.Net Forums
Triumph675.Net Forums (https://www.triumph675.net/forum/index.php)
-   Repair/Troubleshooting (https://www.triumph675.net/forum/forumdisplay.php?f=97)
-   -   wear on wire POSSIBLE 2010 MODEL ISSUES (https://www.triumph675.net/forum/showthread.php?t=33964)
revo2010 08-07-09 01:33
i tought i could share something you should check
while i was still searching for my annoying sqeak when hitting bumps i found something .
look at your stearing damper if it touched the wiring in black tape .
mine was rubbing and did damage to a wire :icon_mad:
i took a tie rap and tied it so it is hgher than damper now
hope it helped someone
daytona 2010 se 500km
see ya
old blue 08-07-09 01:57
see ya
Well done. Something we should all maybe check.
And FWIW, I've taken a few tie raps in my time, too, but where I work now I don't have to wear a tie, so no problem. :whistle:
O.B
MGFChapin 08-07-09 02:12
or just take that garbage damper off
revo2010 08-07-09 02:27
other things to check
you could put an eyes also on radiator hose on the left side .....it rubbed on metal relay holder
t.p.s. wire are pried a lot under a radiator hose
no grease at all on slide bushing on rear caliper
and about sweak think i found it :exhaust clips loose , will see it tomorrow
i have more time to disasemble than to ride it :whistle:
(medical problems)
so see ya
Cloud 08-07-09 03:01
We need more people on the hyperpro GB...
>____>
MGFChapin 08-07-09 03:31
>____>
exactly, easy fix!!!
revo2010 08-08-09 22:46
cricket found
this will help for sure
i passed the 3 last days on this .
could stop thinking about it and i was going crazy about that squeak sound
finally found it!!!!!!!!:hooray:
i have remove every part in front of bike but no use to solve problem
i still dont believe it
gaz tank bolt bushing under seat was the trouble maker .
while i was there fixing it with silicone on bushing i found another stupid thing considering they charged me 600$ for p.d.i.
battery bolt was loose because plastic was underneet the connector !!!
here is the pictures so you will understand :
http://www.printroom.com/ViewAlbum.a...lbum_id=227778
on bushing you see a shinny spot . that was where the sound came from
if you change your windshield ,before putting the new one, check the vaccum device (dont know how to call it).that open and close an air flap
i bet 10$ it is not seated well and the clips are loose .check it and give me news
many thanks for reading me
i know i am hard to read but i usually spreak french :duh:
bottom line is: i love this bike !!!!!
nothing is perfect and all those are minor issue so if you are about to buy a daytona 675 dont back off because of thread like this .
see ya !
revo2010 08-09-09 00:20
sticky
why isnt it on sticky thread anymore?
just curious
AsphaltScraper 08-09-09 11:34
114 Attachment(s)
just curious
A wrong click on my part, sticky restored. Also edited the title as you seem to have picked up on a few things so far. :thumbup:
revo2010 08-09-09 11:42
thanks a lot
:thumbup:
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
