Triumph675.Net Forums
Triumph675.Net Forums (https://www.triumph675.net/forum/index.php)
-   Riders Discount (https://www.triumph675.net/forum/forumdisplay.php?f=94)
-   -   Shoei RF-1200 Dedicated TC-5 (https://www.triumph675.net/forum/showthread.php?t=248925)
RidersDiscount 09-03-19 15:24
5 Attachment(s)
A premium full-face motorcycle helmet, Shoeiís RF-1200 combines a myriad of features specifically aimed at the road-going and trackday rider. Itís lighter, more compact (to the eye at least), better ventilated and yet, more protective than all other RF series helmets to come before. Its evolutionary design is worth your attention, especially if your current helmet is a little long in the tooth.
https://www.triumph675.net/forum/att...1&d=1567538564
Ventilation is addressed with a wind-tunnel shell; four intakes and four exhaust vents draw air through the helmet and straight to the scalp. Enhancing exhaust flow is an integrated wing on the back of the helmet that creates a low-pressure area right behind the helmet, but in a way that doesnít cause buffeting or whistling. The result is a passively enhanced cooling action that youíll be happy with on hot days.
The RF-1200ís shell uses Shoeiís AIM+ six-layer design thatís of a proprietary configuration. The material is hand-laid by skilled Japanese craftsmen before being molded into shape. Four different shell sizes are used to accommodate the entire size range. This is done to insure that these DOT and Snell-approved helmets are as safe and light as possible. The safety aspect of each helmet is aided by two separate, multi-density EPS liners that fit between the comfort liner and the outer shell. The foam itself absorbs energy in the event of an impact but also, aids in ventilation with carefully engineered ports that allow air to pass through to the rider and back out of the exhausts.
That brings us to the 3D Max-Dry interior liner. This fully-removable and washable liner works with all of the ventilation channels to keep you comfy. When correctly sized (TJ is an expert at this!), the helmet fits just-right snug. And with that, keeping the helmet properly positioned on your head, sees to it that maximum safety is achieved.
With the RF-1200, you get a light, safe and comfortable helmet suitable for a wide range of riding conditions. Each helmet ships with extras: a lower chin curtain, Pinlock Evo visor cover, breath guard and helmet bag. All workmanship is backed by a 5 year manufacturer warranty.
For expert sizing guidance and lightning-fast shipping, call TJ on 866.931.6644 ext. 817, send a note to [email protected], or just shoot us a PM and weíll get back to you right away.
RidersDiscount 10-01-19 13:17
1 Attachment(s)
Added detail on top of one of the coolest graphics we've seen this year.
https://www.triumph675.net/forum/att...1&d=1569950029
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
