Race manual for the 675 / 2009-2012 - Triumph675.Net Forums
post #1 of 15 Old 12-26-12, 13:33 Thread Starter
shouldnthave
BOTY Winner
shouldnthave's Avatar
I searched to this in the forum, and ended up having to get it from Triumph. I figured I would post it here for anyone that needed it in the future.
Here is the Race Manual in PDF for anyone making the upgrades this season.
http://assets1.triumphmotorcycles.co...anual_2009.pdf
Take a look at the super trick location they put the rectifier. This is why I had to find the manual, I needed to figure out where the hell I had to move it to. I love where they put it to be honest, and I can't imagine why that is not the stock location.
When you buy the harness it comes with this trick aluminum mounting plate and a few bolts for the mount.
On a side note: For anyone that wanted to know, the race harness is 2.71 LB lighter than the standard. That is not even including all the crap the new harness doesn't support.
675R dedicated track bike.
shouldnthave is offline
post #2 of 15 Old 12-26-12, 14:15
Dave K
This was on my list of things to look for today...thanks!
Dave K is offline
post #3 of 15 Old 12-26-12, 20:50 Thread Starter
shouldnthave
BOTY Winner
Ahh! Now I now why this spot for the rectifier is not OEM...
Do not re-fit your motor before you install the rectifier. You will regret it.
Removal of the rear shock looks like it will make the job doable though. Now if only I had a stand so I could remove it...
post #4 of 15 Old 12-26-12, 21:02 Thread Starter
shouldnthave
BOTY Winner
Step one:
Make makeshift 2x4 holder.
Step two:
Remove the tire you just installed hours ago.
Step three:
Drink a beer.
Step four:
Remove rear shock.
Step five:
Drink a beer.
Step six:
Install the Fing thing.
Step seven:
Repeat all steps less six in reverse order....
post #5 of 15 Old 12-27-12, 01:12
There's nothing trick about that location. That is where it was mounted on pre-09 Daytonas and on all Street Triples including current models. The reason it was moved is that it gets very hot there and is a cause of R/R failures. Yes it can be installed without removing the shock as that is how you do it on replacement kits. The current kit has it mounted rearward not forward like in the picture. The catalog is pretty much 4 years old at this point so there are a number of small changes that have been made that aren't in it.
MacBandit is offline
post #6 of 15 Old 12-27-12, 01:20
Gerard7AA
Gerard7AA's Avatar
thanks for the link
Gerard7AA is offline
post #7 of 15 Old 12-27-12, 01:51 Thread Starter
shouldnthave
BOTY Winner
That's not surprising, but with a 2"+ pipe and the Olin's shock in the way, one of them had to go, and I was not about to remove that FMF and all the safety wire for a fourth time.
I can see how it would be an easy task with the OEM setup, but not with all my oversized aftermarket goodies in the way.
post #8 of 15 Old 12-27-12, 10:12
Ruby Racing
Ruby Racing's Avatar
You beat me to it MacBandit.
Although I have a 2006 model and was just replacing the crap OE R/R with the improved unit, I do have a Nitron race shock fitted, but just the standard pipe, all I had to do to fit the new bracket and R/R was to remove the top shock mount bolt, swing the shock backwards and then fit bracket and R/R. A little fiddly, however not difficult.
Ruby Racing is offline
post #9 of 15 Old 12-27-12, 15:25
Triumph Race Support
They turned the RR forward facing to try and keep it a little cooler. Why or why they didn't put it in the air flow like for example the Suzuki race kit which puts it in one of the fairing openings I don't know. The RR needs plenty of cool air flowing across it not hidden behind the engine.
I have the race kit manual for the pre 2008 if any one wants a copy?
Triumph Race Support is offline
post #10 of 15 Old 12-27-12, 23:03
I don't believe the instructions to face it towards the engine was done so for cooling. I believe it's just because that's the way they use to mount it. The original R/R units came facing forward. It wasn't until the replacement Mosfet units came out that they started facing it rearward. This is long after the race kit manual was published so my bet is it's just old info. It has to cool better facing backward even with the pipe there then it would with no airflow trapped against the hot motor. In any case you could alway wrap that section of pipe to cut down on R/R heat but obviously not wrapping the whole pipe and just a section could affect exhaust flow dynamics.
