By bike was flooded due to Hurricane sandy. It was totally submerged under water for a couple of days. Does anyone know how hard it would be to repair a bike that has been involved in flooding? It is a 2009 model with around 2500 miles on it.
It has been converted to a track bike and unfortunately I did not carry insurance. |
I would assume that water would be in most of the engine as salt water would cause more severe damage. Probably quite the project to repair.
2009 Triumph Street Triple- White Lightning 2007 Triumph Daytona- Golden Thunder ![]() Ozark Mountions Rat Raid- April 25-28, 2013 |
#3 |
I would start with making sure the electrical system was good... ck the fuses & replace the batt. Then if the water was up above the exhaust I would pull the head & make sure there is no water in the cylinders. change the oil & gas, clean the air box/replace filter. I would think as long as your electrical is still go you should run. I would also clean & lube all the electrical conecters, front & rear axles, swing arm pivot, and chain (replace if bad). Replace brake pads & I dont think you would have to but better safe then sorry bleed your brakes. Just do a real good once on it.
#4 |
Thanks guys.
I think it will be a big project as well. But since I do not have any insurance, I want to try it rather than losing the bike. |
#5 |
That sucks to hear man. Hope you are doing well with your recovery of everything else as well as your bike.
Good luck with the rebuild.
come join TheClymb http://www.theclymb.com/invite-from/LouieBruno "Life is all about maximizing experiences and minimizing regrets, and the last thing you want is to regret the experiences you didn't have." -MadMel |
#6 |
Thank you.
#7 |
Noob Hazer
Insurance?
2010 TornadoRed D675 ~ |
#8 | |
![]() Join Date: Jan 2009
![]() To read about the transformation click > Project Trixie Transformation For comparison photo of old R/R with new improved R/R under recall of 2012 click > R/R Comparison Photos
#9 |
Noob Hazer
ah didnt see that just skimmed through. That does suck then.
#10 |
Yes it does
