Cold gas = more power? - Triumph675.Net Forums
Old 12-20-12, 23:59   #1
astat4
astat4's Avatar
Default Cold gas = more power?
So I was at work and its like.... 43 degrees turned my bike on to warm it up. Warmed it up nd took off, so when I go WOT the bike pulled like a mofo.! Was it the cold air its sucking in cause I know motors work better with cold air yeah. But what about fuel? Does it make difference if the gas was cold cause I could feel my tank freezing on my legs..
Old 12-21-12, 00:18   #2
Tex2k2013
Tex2k2013's Avatar
I can't answer your question definitively but I imagine the difference you felt was primarily due to the fact that air is denser when cold, as you pointed out that does increase power a bit.
'10 Tornado Red Street Triple w/ plenty of goodies
Old 12-21-12, 08:48   #3
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
Like Tex said, it has to do with the air being cold and therefore more dense.
Cold fuel actually atomizes poorly.
Side note: I like riding in cooler weather because the throttle response is so much crisper
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 12-21-12, 12:25   #4
Smoke
Smoke's Avatar
Yep, as illustrated by our super/turbocharged resident nutters, our bikes are restricted by air, and not fuel, intake.
Old 12-21-12, 12:49   #5
CitadelPilot
CitadelPilot's Avatar
I remember back in the day racers would chill their fuel...especially in F1. I think it's due to the lack of vapor running through the lines, pure fuel.
Old 12-21-12, 13:31   #6
Serious
Serious's Avatar
Yes fuel like most fluids is more dense at colder temperatures.
Old 12-21-12, 13:58   #7
wfire19
wfire19's Avatar
If i recall correctly back from my automotive class in highschool... you want cold air and warm fuel.... Cold air is more denser you thus giving you more oxygen which is the key to the gas igniting, then you want warm fuel as it being warm helps the gas vapors atomize better allowing for it to mix better with the more denser air.
It follows the same principles, i believe, of using NO2 super cooled, dense air mixing with the fuel gives better HP....
please dont quote me any of this, this is just things i think ive picked up over my short years here on earth
Old 12-21-12, 14:48   #8
Serious
Serious's Avatar
Sorry that's not the case. You want the charge to be as dense as possible therefore colder is always better. Fuel chilling has been banned in almost all racing series for a reason.
BTW, cool fact, the mclaren SLR actually uses the AC system to cool the fuel before it's injected.
Old 12-21-12, 19:34   #9
Dewilmoth
I'm not sure the info about cold fuel being better for power is correct. I know for a fact that turbine aircraft heat the fuel prior to sending it to the motor.
Old 12-21-12, 19:50   #10
jardineD675
jardineD675's Avatar
Does it heat it for aircraft because of the freeze point and for high altitudes? Having it banned from competitions sounds like it def gives an edge.
