Hey everyone
Have been looking for recent info but can't find much on the 6k service. Around how much did you pay and did it include the throttle body balance? Thanks, just want to be informed when I start calling dealerships around. Sent from my iPhone using Motorcycle.com Free App |
yes, around $750, if i remember correctly
<----yea, thats my cat '07 daytona '07 FJ '04 Audi A4 '97 wrangler '92 mustang gt
#3 |
Varies wildly, by region and dealer.
#4 |
You don't really have to do much around the 6K mark.
Change oil/filter, Coolant, Air filter, maybe check spark plugs. Could do it yourself for $150 and your time. The bigger service is at 12K miles.
#5 |
$750 for a minor service? Whoa that sounds way too much.
I got my 10k km (6k mile) service done today. Cost me $350 (2*$120 labour) the guy fully went over everything and checked it, even cleaned my chain, and I was going to do that this weekend when I intend to give it a well deserved clean over. I doubt they would do a throttle adjustment already, not sure whats involved. Your manual book will outline what should be done at each service anyway, so check that. Sent from my iPhone using Motorcycle.com App
'11 675R Akrapovic Pipe + Evotech Fender Elim, Triumph Tinted Screen, Triumph Gel Seat, Triumph Carbon Tank Pad, Tech Spec C3 Grips, Pazzo Gold Levers, Cox Radiator Guard. |
#6 |
According to the service manual, the 6k service consists of:
Engine oil cooler - check for leaks Engine oil - renew Engine oil filter - renew Engine ECM - check for stored DTCs (codes) Spark plugs - check Throttle bodies - balance Throttle cables - check/adjust Cooling system - check fo rleaks Coolant level - check/adjust Fuel system - check for leaks Lights, instruments & electrical systems - check Steering - check for free operation Headstock bearings - check/adjust Forks - check for leaks/smooth operation Brake fluid levels - check Brake pad wear - check Brake master cylinders - check for oil leaks Brake calipers - check for leaks and seized pistons Drive chain slack - check/adjust Drive rubbing strip - check Fasteners - inspect visually for security Wheels - inspect for damage Tyre wear/tyre damage - check Tyre pressures - check/adjust Clutch cable - check/adjust Stand - check operation So, on that list, the only thing that might be tricky, is to balance the throttle bodies. I copied the photos of the manual from the balancing section for you ![]() ![]()
#7 |
Location: 90 miles from Brainerd International Raceway, Minnesota
Good stuff, Hokie.
***Current bikes*** '12 Triumph Daytona 675R '06 Yamaha FZ1 (Sport-tour) '05 Honda CRF50-88cc (Mini SM race bike) '04 Yamaha YZF-R6 (Track bike) '03 Honda GL1800 (Lazy-boy) '02 Honda XR50 (Pit bike) '01 Suzuki DRZ400S (Dual sport) |
#8 |
Thanks!!! I called around and best price for everything including throttle bodies and ECU updates is about $230. So might as well get everything done
#9 |
I see you live in the same area as me, mind sharing which shop gave you the best price? I'm due for my service soon as well.
2012 Street Triple R 2013 Diavel AMG |
#10 |
you know what, i believe i gave the 12k service price, now that i think about it, 6k was around 3oo, i think,
