Tire changer question. - Triumph675.Net Forums
Old 12-18-12, 17:52   #1
chooch
chooch's Avatar
Default Tire changer question.
A friend of mine has a shop tire changer. He uses it to change tires for his race car. My question is would I need anything special. Like a adapter or something to change my bike tires ? It would be pretty great if I could just use his machine instead of paying a shop $30 to do it.
Old 12-18-12, 19:20   #2
tooblekain
tooblekain's Avatar
PM illsynd. He would know.
AAIK, no special tools needed.
Old 12-18-12, 20:00   #3
old blue
old blue's Avatar
I have a manual bead breaker purchased for $100 or so.
Team this up with a static balancer, some rim savers, levers and weights, and you are in business. I've never looked back...it's easy, and gets easier every time you change tyres.
The bead breaker is handy not just for breaking beads, but as a stand to work on as you go about the whole process.
Like so many things in life, the key to it all is lots of lube.
O.B
Old 12-18-12, 20:08   #4
Noodles
Noodles's Avatar
As long as the operator knows what he's doin', as well as knowing the machine's quirks, should be able to swap tires without marking the rims. I use a 25yr old tire changer without all the new spiffy rim protectors, and I haven't marked up rims. It's 95% operator's care. And it's just an automotive changer, no special bits required.
Nuno!
Old 12-19-12, 00:26   #5
99% of tire machines should work for motorcycles or cars. However if it's the style that uses a center axle to hold the wheel in then know. If it's a modern type with a swing out arm that drops down and sits on the edge of the rim then it should work however there are different types of wheel clamps and they don't all work well on motorcycle rims.
Old 12-19-12, 08:11   #6
projectrang
projectrang's Avatar
I changed my tire on a conventional tire changer just the other day. I just broke the tire down, clamped on the outside of the rim, and pulled it off with no problem. I didn't balance it though, I used beads.
Old 12-19-12, 09:35   #7
chooch
chooch's Avatar
Yeah it's a newer style changer. He really wasn't sure if it would work or not. I figured a wheel is a wheel. I'll try it in a couple days with my rear tire...
He actually has a wheel balancer too but i'm almost certain that wont work. But its ook I have a static balancer already.
Thanks for the answers.
