Feeler: Stripped wiring harness & ECU - Triumph675.Net Forums
Parts Sell, trade or give away your parts here. FS, WTT, FF all welcome.
post #1 of 3 Old 12-06-12, 16:16 Thread Starter
sittingturbo
sittingturbo's Avatar
I wanted to see if anyone would be interested... I have stripped my old wiring harness for the track (2nd Gen 09-12). I eliminated a ton of the stuff like lights, snorkel valve, kickstand sensor, shift sensor and stuff. Took out a ton of wire, more can still be removed like the idle adjuster, o2 sensor. I could also put the clutch sensor back in since I just bought a new sensor the other day before I changed my plans again!
I just bought a used race ecu, and quickshift so I will have to get the race harness. I no longer need the stock (stripped) harness or ecu. Instead of it just laying around I wanted to know if anyone needed this? I know some people are not willing to strip into a perfectly good harness, the work is already done here.
This is only a feeler, because I have a lot of the tape pulled off the harness, I was getting ready to strip the ignition, o2 sensor, idle controller and some other stuff before I ran across that smoking deal, I will have to re-tape up the harness, but will not bother if no one needs it.
sittingturbo is offline
post #2 of 3 Old 12-08-12, 03:38
1 riktig svensk
1 riktig svensk's Avatar
Send a message via MSN to 1 riktig svensk
How much for the ECU?
2008 SE converted to Striple
My Gallery
Find me on Facebook!
1 riktig svensk is offline
post #3 of 3 Old 12-08-12, 10:11 Thread Starter
sittingturbo
Lets say 150 shipped which is much cheaper then anything on eBay.
You may not post new threads
You may not post replies
