Do u have scratched headlights?? - Triumph675.Net Forums
post #1 of 7 Old 12-02-12, 21:20 Thread Starter
jardineD675
jardineD675's Avatar
If the scratchs and wear isn't to deep, u can get them restored.Headlight restoration just google for the service in ur area and find someone that's been doing it for awhile etc... Will end up saven u some definate cash, and they look close to perfect, ran me 70 bucks
jardineD675 is offline
post #2 of 7 Old 12-02-12, 21:26
f4nm4n
f4nm4n's Avatar
Now are you talking scratches on glass lenses? or on plastic ones? Some of the newer headlight units are being replaced from a recall that causes them to scratch/crack.
f4nm4n is offline
post #3 of 7 Old 12-02-12, 22:10 Thread Starter
jardineD675
Plasticsssssss
Defenatly not glass
post #4 of 7 Old 12-02-12, 22:11 Thread Starter
jardineD675
There's a process of fine sanding that's done on plastic, then can either be wet sanded, or sprayed with specail spray then cured with uv lamp.
post #5 of 7 Old 12-03-12, 16:36
Ruby Racing
Ruby Racing's Avatar
I seem to recall you can do this with some sort of dentists equipment. Can't for the life of me remember what it is though.
Ruby Racing is offline
post #6 of 7 Old 12-08-12, 22:46
Tucker2.0
Tucker2.0's Avatar
Send a message via MSN to Tucker2.0
Honestly a little light grit polish and clear coat will do the same thing. Remember to clear coat over it after you work on your headlights or the plastic will tarnish.
2007 SV650S -RIP suziQ
2010 Daytona 675SE -I miss my SV, but damn that daytona!
1980 Honda cm200t (running work in progress)
Tucker2.0 is offline
post #7 of 7 Old 12-08-12, 23:46 Thread Starter
jardineD675
That's pretty much the same, just putting info out there, so guys know its an option, to save cash.
