hidden heated grip switch - Triumph675.Net Forums
Old 11-30-12, 17:55   #1
monkey wrench
monkey wrench's Avatar
Default hidden heated grip switch
I've learned a lot from this forum so here's my first contribution.
I 'm really uptight about drilling holes in my bikes and I want things to look clean. this is my solution for mounting the grip heater switch. I could have put it next to the gauge cluster but I liked this better. I put it between the seat and sub frame on the right hand side. the starter relay and differences in the plastic, prevented my from using the left hand side.
Old 11-30-12, 18:16   #2
noclue90
noclue90's Avatar
Looks like it should be a factory option. Nice work!
2009 Triumph Street Triple- White Lightning
2007 Triumph Daytona- Golden Thunder
Ozark Mountions Rat Raid- April 25-28, 2013
Old 12-01-12, 00:04   #3
Logans08Daytona675
Logans08Daytona675's Avatar
Looks clean where did you get the heated grips from
Old 12-01-12, 00:14   #4
As much as I switch from low to high and on and off that would be really inconvenient. i put a switch in my left combination switch housing down below the turn signal switch. It barely noticeable. I'm with you though I hate drilling my bike or making any changes that are permanent. That said I'm doing away with that and going to a switch that bolts on to the clutch perch.
I picked up a Heat Demon kit over summer for $60 and it has the switch. I really like this kit because the Heat Demon warmers have two different heating elements built into the warmer you wrap around the bar. So there is a smaller element for low temp and a second element for medium and both are used for high. So no resistor needed.
Name:	Screen Shot 2012-11-30 at 9.11.40 PM.JPG
Old 12-01-12, 00:57   #5
monkey wrench
thanks noclue.
i got the warmers from cycle gear. they were/are $20 on sale. trackside brand i think.
it's not too difficult to reach. i can toggle the switch while i ride. although not as convienant as a switch on the bars.
that switch looks cool and appears to be a rheostat. that beats having just the high low option.
Old 12-01-12, 01:02   #6
Just a tip. If you run hi/low with a resistor. Make sure that resistor is where it can get some airflow. It will get very hot. Hot enough to melt plastic if it doesn't get some air. Ask me how I know.
Old 12-01-12, 01:40   #7
monkey wrench
thanks. i have the resistor in a safe spot on the frame.
Old 03-17-13, 12:05   #8
drstimpy
drstimpy's Avatar
Macbandit does the wiring work with bar end caps or weights? The video was for open ended bars. My bars have solid ends except for the bolt hole for the weight or cover. Thanks!
Thanks
Sent from Motorcycle.com App
Old 03-17-13, 13:40   #9
Good timing. I actually finally got around to installing these yesterday. Short answer yes they work as long as the bars are hollow. The end of the bar is not important as long as you get the correct kit. They make a kit that puts a metal warmer plug inside the bar and they make a kit that wraps around the outside like most kits. The outside wraps are the ones you want. Something I discovered during installation this kit has a single warmer element but the switch is a controller with 4 heat settings. Still no resistor to install though so no worries about heat generation. The cheaper kit without the controller uses two separate elements for hi/low but the more expensive kit has for levels with one large element.
As for installation you have to drill a hole for the wires of the controller as they come out the back then go through the bar and back out where ever you want them to but close to the handlebar clamps. If you use them don't drill a hole as big as they ask you to it's ridiculously huge. Just drill a hole just large enough for the controller to sit flush on the bar which is about half the size they suggested.
Old 03-17-13, 18:52   #10
drstimpy
drstimpy's Avatar
Thanks. Been looking for this mod awhile.
