Dealing with rust/pitting - Triumph675.Net Forums
Old 11-29-12, 15:53   #1
moanthebairns
Default Dealing with rust/pitting
I bought a second hand 2006 daytona a few months or so ago.
It only had 1000 miles on the clock and I got it for a steal. The Only thing wrong with it is that it was showing signs of rust/pitting in places.
Ive since replaced rusted bolts and washers etc, now I need tackle the pitting on the engine, footrests, discs and a bit of rust at the front left fork leg.
Anyone else had problems with rust/pitting. How did you get rid of it? Whats the do's and donts.
I plan to just use some autosol and get what I can off, then acf-50 the whole bike to solve the problem. It could be that the previous owner never kept in a garage. He put it in a huge carrier bag that couldnt breath and caused it more harm than good.
Old 11-29-12, 16:23   #2
Decipher
Decipher's Avatar
That poor thing must have been exposed to ALL the elements. I can't even imagine how this happens. It sounds like a decent plan to start but I've never had to do something so extensive. Good luck and post up some before and after pics so we can admire your work!
Sent from my Samsung Galaxy S II using motorcycle app
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
Old 11-29-12, 17:34   #3
llenta
llenta's Avatar
Originally Posted by moanthebairns View Post
I need tackle the pitting...footrests, discs and a bit of rust at the front left fork leg.
the perfect solution would be a set of attack rear sets, some galfer rotors, and a set of Ohlins .
But seriously, a green scotch bright pad does wonders on the rotors and fork leg. It's abrasive enough to get the rust off and clean it, but not so much that you will do any damage to the metal. Just take your time, it shouldn't take more then 10 minutes or so for each one.
I'm sure the same could be done for the engine, but I'm not sure.
Old 11-30-12, 00:20   #4
It's not usually storage that causes these issues. I had a customer who purchased a brand new Street Triple then trailered it down to the Palm Springs area for 6 months and came back. After that the bike was covered in rust and pits. My bet is that it was the trailer ride. If you trailer use an enclosed trailer or one that has a rock guard at the front of the trailer.
The rust and pits on the fork leg are the hard part. If it's especially pitted it will cause a leak. In this case a replacement leg would probably be in order. If you can feel the pit with your finger nail then it may be that deep. I would try buffing it out first with a fine metal polish.
Old 11-30-12, 04:57   #5
moanthebairns
the rust is actually on the suspension stantion tube. it’s very small so I plan to just take it easy with a scotch pad and then maybe some polish. it’s out of reach of the forks "normal" compression range so I might be ok. Failing that it will be a new stantion. Aslong as I get some acf-50 on it that will halt any further rust.
As I say he never bought an actual cover for it. I leave my ninja outside with a ventilated cover its 13 years old and has no signs of rust. This tool put a huge thick plastic cover over it and the water was all trapped in for months. It would have been like a green house.
It shouldn’t be too difficult, corrosion is fairly common over here in Scotland as we salt our roads for 4 months out of 12 due to the cold. I’ve seen a few before and after shots of what can be achieved. It’s not really that bad to be honest it just gives me something to do when its -4 degrees at the weekend and I can’t get out on the bike.
Old 12-03-12, 06:26   #6
moanthebairns
set about it at the weekend
fairings off, the other halfs toothbrush and some autosol and a before and after of my work. top is before bottom after.
I called it a day when it was -2 degrees and went and done some work on the ninja. took the fairings inside, washed, t-cut and waxed them. Other half wasnt too crazy about the tar i left on the floor after.
ill try a copper brush and see if i can get it looking any better then acf-50 it to stop rust. dont know how to do the brake discs however.
ID:	34253   Click image for larger version
ID:	34254   Click image for larger version
ID:	34255   Click image for larger version
ID:	34256   Click image for larger version
Old 12-09-12, 16:42   #7
moanthebairns
before and after. Used lots of wire wool at the weekend
covered the bike in acf-50 to stop further corrosion jobs a good one.
ID:	34345   Click image for larger version
