Help! '06 675 finally died - Triumph675.Net Forums
post #1 of 17 Old 11-28-12, 23:33 Thread Starter
Faster675
Faster675's Avatar
After 30k of hard miles, track days, and racing, the motor died on the way from work yesterday. .... Sounded like maybe something in the valve train let loose... Like maybe a valve spring failed?
I have drained the oil, it is clean
I have removed the timing chain cover, timing chain is fine
I have removed the camshaft (or valve) cover. ... Cant see anything wrong.
What should I do next to determine what went wrong?
Go Fast, Take No Chances !
Faster675 is offline
post #2 of 17 Old 11-29-12, 00:38
Most common valve train failure is the head of the valve to drop off. Look down the spark plug holes and see if you see anything in the cylinders. If not do a leak down test. If you can't do that at least do a compression test. If you have a bad cylinder then there is no need to do anything else until you pull the motor.
MacBandit is offline
post #3 of 17 Old 11-29-12, 10:59 Thread Starter
Faster675
Faster675's Avatar
Thank You Mac. . . . . Fook, it is hard to see down there. .. I can barely see into cylinders 1 & 3. ... Pretty much cant see into number two. ... Am i going to need a borescope? any suggestions on a good, reasonably priced one (that will fit past the spark plug threads) ? Or?
post #4 of 17 Old 11-29-12, 11:32
The cheap borescopes that will fit through the spark plug hole are still $200. You can use a mirror and a bright flashlight. I'd just skip this step and do the compression or leak down test.
post #5 of 17 Old 11-29-12, 14:02 Thread Starter
Faster675
Faster675's Avatar
Thank You Again Mac ... I will run a compression test tonight (assuming that my compression tester has an adapter for our spark plug hole) .... probably an obvious question (answer) ... do I need to have the ECU connected to spin the starter ?
post #6 of 17 Old 11-29-12, 14:05
post #7 of 17 Old 11-29-12, 18:30
LIV2
LIV2's Avatar
Just out of curiosity mac, if the valve head did drop off what kind of work would he be looking at for a repair?
LIV2 is offline
post #8 of 17 Old 11-29-12, 18:47
jethead
I gotta chime in here, If I had a bike with only 30K miles on it and it died I'd be looking at where I failed in general maintenance. I'd also be pissed off, really pissed off.
Modern sportbikes are able to go over 200K miles with proper maintenance.
You also make a comment that it's had "hard" miles you give an example of "track days", sportbikes are BUILT FOR track days. That is not hard miles. They are made to rev out and brake hard and do it for a LONG time, WITH PROPER MAINTENANCE.
Sounds like you need to learn how to properly maintain your ride.
The sheep remain inside the pen,
Though many times they've seen the way to leave.
jethead is offline
post #9 of 17 Old 11-29-12, 18:58
Noodles
Noodles's Avatar
I don't recall the op saying anything about lack of maintenace, or maybe you have his log book... 30k is pretty good, considering some of the 675's have had valves drop b4 first service was even due.
Nuno!
Noodles is offline
post #10 of 17 Old 11-29-12, 18:59
LIV2
LIV2's Avatar
I'd believe that was the case if it wasn't a Triumph.
LIV2 is offline
