Daytona Replacement Screws - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Regional forums > United Kingdom
United Kingdom UK Forum, rides, get togethers and events
Old 11-25-12, 16:04   #1
moanthebairns
Default Daytona Replacement Screws
Hi all
After spending many a fun hour trying to take the daytona fairings off Ive decided I never want to go through this torture again. Those bloody philips head push in screws/raw plug like things are a nightmare.
Has anyone replaced theirs with anything easier?
I seen a few yanks had managed it any one here in the UK? If so where did you get the screws/bolts from.
Old 11-25-12, 17:27   #2
Knolly
Knolly's Avatar
Direct replacements: http://www.autozone.com/autozone/acc...er=493505_0_0_
Old 11-28-12, 10:22   #3
moanthebairns
thanks I seen that link on the fairing how to thread but sadly I cant find them anywhere in the uk.
Are these much better than the philips ones?
Old 11-28-12, 15:08   #4
tooblekain
tooblekain's Avatar
Believe it or not...I found the best way to make it easier is to take the OEM plastic screw on rivets and actually beat them down with a rubber mallet for a bit....but not too much where it's cracking and falling apart. This will soften it up to the point where you can just push them out from the pointy side.
For replacement I go to Lowe's and they have 1/4" ones exactly like OEM for much cheaper.
The other possibility or alternative is to install DZUS fasteners with S-clips. You will need to do some drilling a rivet gun to do this mod.
Old 11-28-12, 16:28   #5
Knolly
Knolly's Avatar
Totally didn't notice this was in the UK forum, sorry!
And yeah they're much better, you just push them in to secure them and pull them out to remove them. Takes 2 seconds each.
Old 11-28-12, 16:30   #6
MadMel
MadMel's Avatar
I read someone's post on here about how they drilled the holes out a bit and use wellnuts (windscreen bolts). Seemed pretty clever to me.
Old 11-28-12, 17:54   #7
allaussiegrown
allaussiegrown's Avatar
I hated then at the start too. The I figured out you cannot put any pressure on then add you are screwing them out.
I found if you have just the right but and an adaptor it will come out with ease.
The moment you you put pressure on then they pop back in.
I still get those 'oh shit' moments.... The day I don't, is the day I stop riding.
'11 675R
Werkes Slip On Pipe + STD Fender Elim + Intergrated Tailight - ZG Double Bubble DS - Dual HID Headlights and Angel Eyes with Coloured Headlight Housing - Red Seat Cowl - LED Strip Indicators - 1050 Throttle Tube -
Attack Reasrsets (Red Pegs) - Powdercoated wheels and Sidestand - GB protection Kit - CRG Levers folding - Saddlemen CF Track Seat - Watsens
Old 11-29-12, 15:45   #8
moanthebairns
http://www.mossplastics.com/mss/mss-...&search=495202
i got some from here.
I plan to take the fairing off at the weekend again but start from the bottom up ill try not being so rough with the screws
