Safety Wiring - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 Racing Forums > General Racing Discussions
General Racing Discussions Discussion area for any non 675 related racing (Moto GP, World Superbike, etc) & general race set up / questions.
Old 11-20-12, 22:29   #1
ScotiC
ScotiC's Avatar
Default Safety Wiring
So I'd like to prep my bike to try my hand at racing. I don't have a drill press or have access to one. Can anyone tell me if there are kits for predrilled bolts and the sort?
Old 11-20-12, 22:57   #2
dubguy85
yoyodyne sells them, pro bolt sells them.
Old 11-21-12, 00:05   #3
old blue
old blue's Avatar
There are pre-drilled sets out there, but to do it on the cheap you'll probably manage with just a vice, a cordless drill and some patience. That's how I did it.
Mind you, you'll need fresh, sharp drill bits if you start working on stainless, but it can be done.
O.B
Old 11-21-12, 02:42   #4
Rink675
Rink675's Avatar
O.B
I just assumed everyone did it this way! lol
2007 Triumph 675 Race Bike
Old 11-21-12, 22:11   #5
ScotiC
ScotiC's Avatar
Thanks guys. I contacted pro nuts and it looks like its best to come up with a precise list of the bolts needing holes- otherwise it's cost prohibitive for me. Looks like I've got some homework to do. However- if anyone has a list then I'd gladly take that- cheers!
Old 11-22-12, 00:08   #6
Rink675
Rink675's Avatar
Incase you decide to do it yourself.
Old 11-27-12, 14:18   #7
ttilghman
you can get a drill press at sears for under and around $100. if you're racing, you're gonna need one...you'll never stop safety wiring new bolts/nuts/covers/etc. use cobalt bits and buy twice as many as you think you'll need. doing it with a hand drill is OK in the pits when you have no options, but to drill an entire bike you'll spend as much in broken bits as you would a press...especially when drilling adjacent faces on a hex.
Old 11-27-12, 18:53   #8
tooblekain
tooblekain's Avatar
+1 on cobalt bits. Also be sure to get cutting oil and a spring loaded punch to make a divot/dot for where you want to drill. Doing this will prevent the drill bit from walking.
Old 11-28-12, 00:49   #9
shouldnthave
shouldnthave's Avatar
+1
I strongly *shakes fist* recommend "Tap Magic" for the cutting oil.
675R dedicated track bike
My BOTM thread.
Old 11-28-12, 05:06   #10
ScotiC
ScotiC's Avatar
Copy! Drill press with lots of cobalt bits and some Tap Magic. I thought I'd just buy some predrilled bolts but I'm thinking I'll be way ahead by doing it myself in the long run. Thanks for the advice.
