Keyless Seat Release - Triumph675.Net Forums
Old 11-20-12, 08:50   #1
MacaveliMC
MacaveliMC's Avatar
Default Keyless Seat Release
So I've removed my ignition and rewired my (track)bike so that it is keyless, but now I'd like to eliminate the need for a key altogether, since it's quite annoying to have to keep track of a key simply for fueling and seat removal.
The keyless gas cap is an obvious solution, but where I am stuck is how to make the seat removal keyless as well.
Has anyone done this? I've searched these here forums far and wide and was surprised to find no info on this potential mod. Any ideas???
I'm not driving fast - I'm flying low
"I actually just have my throttle cable pulled so its
wide open even when i start the bike. balls to the
wall is how i live, screw stoplights and slow people."
- TwoWheeledWonder
Old 11-20-12, 09:00   #2
Godly
Godly's Avatar
I've never seen anybody do it, but it would be simple, just attach a "pull" of some sort on the linkage that's under your seat.
"Faster we become, until the thrill of speed overcomes the fear of death"
Old 11-20-12, 09:57   #3
Far Canal
Far Canal's Avatar
The ones I've seen have taken the cable out of the locking mechanism and cable tied it to the sub-frame. Then you just pull on the cable to release the seat.
Old 11-25-12, 14:08   #4
antirich
antirich's Avatar
Yep, just pull the lock and leave the cable where it is. A simple pull just releases the seat.
Or, get a sbk tail.
'11 675R
CCS#696
http://www.dragonflyinteractive.com
Old 11-26-12, 18:51   #5
piercejb
piercejb's Avatar
pull the lock out then tie the cable to some ring like a key ring so that the cable wont pull back through the hole and there you go. Just pull the ring to release the seat.
