Project Streetona - Triumph675.Net Forums
Old 11-17-12, 18:28   #1
Tst
Tst's Avatar
Default Project Streetona
Project Streetona is getting closer by the day. I have a 2012 street and i absolutely love it, but i feel that i could make her stand out just a but more by replacing the rear end of the bike to that of a Daytona. so for the past few weeks i have been piecing together the parts necessary to make this a reality. Today i purchased the battery box and it would be the last large item i need before i can start taking the proper steps to do the swap. From here im just gonna need to order bolts that id need and its good to begin. Starting tomorrow, I'm going to remove the body panels and rear subframe off the street and putting up the rear subframe from the Daytona. Im looking forward to this project because although it wont b a long one, it will b a noticeable change. Pix and possibly even a how-to will come as i get the items added.
Old 11-17-12, 19:27   #2
Nastybutler
Nastybutler's Avatar
Looking forward to seeing the process and end result. Good luck!
2012 Street Triple - Phantom Black (Trinity)
Trinity's Mod Thread
Old 11-17-12, 19:50   #3
Tst
Tst's Avatar
Thanx nasty, i'm very excited and will b more then happy to do what i can for those who have even considered this swap.
Old 11-17-12, 20:53   #4
Dave73
Dave73's Avatar
I did this last year. It's all a bolt on deal as long add you have all the necessary Daytona stuff: subframe, battery, battery tray, body panel, seats. I reused the stock street triple lights. The wiring is a stretch but it will work without cutting or splicing.
The trickiest part is the exhaust, as that won't swap. What do you plan to do for that?
09 Street Triple
06 Track Triple
Old 11-17-12, 21:05   #5
Tst
Tst's Avatar
A hybrid. Upon looking at the stock street and Daytona mid pipe, the first several inches of both r identical. Minus the different ends. Im gonna splice the lower street mid pipe to the upper daytona. If i decide to go back to a street exhaust, a mid pipe should be fairly easy to find. Hey dave, u have pix of this swap? Also any help if i need it would be greatly appreciated
Old 11-17-12, 21:16   #6
Tst
Tst's Avatar
On several forum pages i read that the battery got small enuff to put into the daytona battery tray. Did i read it right?
Old 11-17-12, 21:25   #7
noclue90
noclue90's Avatar
Looking forward to completion pics.
2009 Triumph Street Triple- White Lightning
2007 Triumph Daytona- Golden Thunder
Ozark Mountions Rat Raid- April 25-28, 2013
Old 11-17-12, 22:22   #8
Dave73
Dave73's Avatar
I have an 09 Striple and used a tail from an 06. The 06 daytona battery tray will not easily accommodate the striple battery. I believe the 09 and newer Daytona tray holds the larger battery, but I cannot confirm.
You will also need the Daytona passenger pegs if you want those. I fabbed up a license plate bracket as well.
09 Street Triple
06 Track Triple
Old 11-18-12, 03:01   #9
Ruby Racing
Ruby Racing's Avatar
Subscribed! Good luck.
Old 11-18-12, 04:38   #10
ChickenStrips
ChickenStrips's Avatar
That looks awesome Dave73
Good luck Tst, if Dave73's is anything to go by, you're going to end up with a damn good looking bike
Its the afternoon on the last day of the holidays and its your call: Reg Lindsay`s Country Homestead with Mum and Dad or a painters plank on the top of a 12 gallon drum and your YZ80E...
