R/R Regulator Rectifier old & new comparison photo - Triumph675.Net Forums
Old 11-16-12, 13:35   #1
Ruby Racing
Ruby Racing's Avatar
Default R/R Regulator Rectifier old & new comparison photo
As I've just fitted my new R/R under the recent recall I though I would post a picture of the old R/R next to the new replacement so all can see the difference.
This was for a 2006 Daytona where the R/R is mounted at the back of the motor next to the shock. The new R/R comes with a new mounting bracket and a new sub loom.
The old one is on the left, the new one on the right together with the sub loom and the bracket.
Hope this helps.
ID:	34044   Click image for larger version
Old 11-16-12, 13:55   #2
Thank you. That confirms that it's the same kit they've been using for the past couple years.
Old 11-16-12, 14:05   #3
Ruby Racing
My pleasure MacBandit.
Old 11-16-12, 14:17   #4
bballman01
bballman01's Avatar
Send a message via AIM to bballman01
So does the bracket move it at all or just accommodate the new shape?
If ur not ridin' ur not livin'
Old 11-16-12, 17:52   #5
Ruby Racing
It just accommodates the new shape as there isn't really a lot of room for much else. It sits in the same place as the original.
Old 11-17-12, 02:38   #6
NJ Steve
I bought my 675 used and it is a 2009, does anyone know if there was a recall for my year? Im not in warranty anymore.... I'd like to have mine swapped out as well! Thanks
Old 11-17-12, 11:58   #7
Ruby Racing
Look at the sticky started by MacBandit in this section. It details the VIN's covered. Or just call your dealer.
Old 11-17-12, 13:45   #8
bballman01
bballman01's Avatar
Good to know, Cheers Ruby
Old 11-23-12, 17:40   #9
toronto675
toronto675's Avatar
Talking
Just got my rr from dealer for my 06 track bike .Thank you for mounting info!
Old 11-23-12, 18:50   #10
Geof3
The new bracket fits slightly different and makes getting to the bolt on the left side a bit of a pain. That is, if you don't want to remove your shock. Took a little creative finesse to get it all bolted up. The new unit just looks more robust and the connectors are far better! Have you done your fuel pump relay yet? It's on recall too. If not, get that loom and do it while you are in there...
