Which plug goes where? - Triumph675.Net Forums
Old 11-15-12, 06:29   #1
rubenastley
Default Which plug goes where?
Hey guys, first time taking the daytona apart and i left it butchered for a couple months and now putting it back together.. got most of it together but a few plugs and vacuum hoses im not sure where they go? / don't remember lol..
I know two of them go into the fuel tank but not sure about the third?
Two vacuum hoses? where do these go?
Which vacuum hose goes here? is it the long one thats origin is located near the O2 sensor?
I assume most of the plugs are fool-proof... if they fit correctly then its in the correct plug? unless there are identical connectors with different color codes? sorry i'm unfamiliar with the plugs and probably should of taken more note when i took them apart lol.. Also i tried to do a compression test a while back and the bike would only crank over once and then die.. is it because the tank is removed from the ECU? any help is appreciated!
Old 11-15-12, 06:38   #2
miky92
miky92's Avatar
Send a message via MSN to miky92 Send a message via Skype™ to miky92
the two hoses are for the tank... for vents.
and connectors, depends form the year...2 are for tank for sure, the third may be for the sensor of the airbox (if you removed also it, in this case remember to attach also the hose from throttle body to the sensor)
if you leaved only the tank... then there are all for tank i guess :P
Old 11-15-12, 08:13   #3
sittingturbo
sittingturbo's Avatar
And if the 3rd isn't for the previous 2 spots mentions... It could be for the map sensor...
Also, the 2 for the tank will only go to the intended plug, so no issues there, they are keyed to one another.
Old 11-15-12, 09:25   #4
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
I believe the connector at the top of the pic is for the ISM(Idler Stepper Motor)
If the four wires are:
orange/pink
orange/blue
orange/white
orange/brown
the tube coming out of the throttle body may be for the intake flapper. need a better picture
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 11-15-12, 09:43   #5
Knolly
Knolly's Avatar
The identical (aside from color) connectors go to the tank.
bRown goes to the Right, bLack goes to the Left.
Capitalized for emphasis on how I remember.
Old 11-15-12, 10:57   #6
TwoWheeledWonder
Noob Hazer
TwoWheeledWonder's Avatar
Actually the brown and black have those little tips on opposite sides. So they wont just go on either connector.
2010 TornadoRed D675
Old 11-15-12, 11:14   #7
Red October
Red October's Avatar
Two connectors on the bottom (orange and black) go to the gastank. The easy way to remember is:
Orange goes right next to the fuel line plastic elbow which also has the orange locking tab on it.
Vent hoses are pre-bent so just their position should tell you approximately which side they are on (they criss-cross under the tank), but ultimately it should n't matter...
Old 11-15-12, 12:36   #8
Knolly
Knolly's Avatar
Well shiiiit, learn something new every day.
Old 11-15-12, 12:52   #9
TwoWheeledWonder
Noob Hazer
Hahaha Triumph engineers where thinking when they got to that area ahaha
And it is ok, its my engineering eye that catches those things haha
Old 11-16-12, 00:17   #10
No they thought about it after everyone was connecting it wrong. I know on at least some Triumphs they can be reversed. I don't need to explain how I know this do I?
