Heat Wrap? - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Maintenance and repair > How To's
Old 11-14-12, 09:55   #1
!!675R!!
!!675R!!'s Avatar
Default Heat Wrap?
Anyone got a how to for heat wrap? Im sure I could just YT it, but wasnt sure if anyone here has somthing that could help. I plan on wrapping mine headers back. If anyone has any tips, what tools (specifically for the ss ties) and so on would be great!
2011 Triumph Daytona 675R 2007 KTM 950SMR
Old 11-14-12, 10:51   #2
Bamboo671
Bamboo671's Avatar
Send a message via Skype™ to Bamboo671
The ss ties are shit that they give you! Go to your auto parts store get and the screw clamps. The ss zip ties will fail on you. Soak the wrap in water before applying and then depending on the thickness of your wrap ensure you have an overlap. The instructions should tell you the recommended overlap. Let them dry and then spray it with whatever they came with. I went and got some high heat header spray from Auto Zone for touch ups.
1997 YZF100R/Thunderace - 12 o'clocked it!
2008 Jet Black Daytona 675 - I called her Tasi!...she's dead!
2013 Daytona 675R - Her name is Tasa!
Old 11-14-12, 10:58   #3
dabird
dabird's Avatar
Send a message via Yahoo to dabird
My wrap came with stainless ties, but I used stainless steel hose clamps. easy to do, and I feel confident they will be good and tight. If they do need to be tightned later. No problem.
Old 11-14-12, 11:43   #4
!!675R!!
!!675R!!'s Avatar
Ok cool, good info on the ties, looks like ill go with the clamps instead. I have the lava wrap, and the spray isnt really required is it? I mean I know it will help the wrap last longer but other than that are there any benefits? Also, how much of a bitch was it to do your whole system? I heard the mid pipe doesnt exactly just come out easily lol
Old 11-14-12, 12:00   #5
Bamboo671
Bamboo671's Avatar
The hardest part when I did from the headers back was just the headers. The three drop down pips and then finding a way to cleanly make it come into one was the most difficult for me. I would use the spray since it's supposed to help cure the wrap.
