Cam advancing - Triumph675.Net Forums
post #1 of 8 Old 11-10-12, 18:47 Thread Starter
Rink675
Rink675's Avatar
Cam advancing
On a 07 motor I thought I heard something about advancing the cams +2 helps with the power. Can I simply just advance the cams or whichever cam +2 teeth and get it tuned or would I be having to change out the valve springs and stuff as well?
2007 Triumph 675 Race Bike
Rink675 is offline
post #2 of 8 Old 11-10-12, 19:29
Noodles
Noodles's Avatar
UHHH, NOOOOO! 1 tooth off usually means that your valves are gonna hit your pistons. Unless you've already got your cams degreed, and your slotted sprockets marked for different degrees, it is a very involved process, which when done wrong, will be catastrophic, and costly. Go on youtube and search cam timing.
Nuno!
Noodles is offline
post #3 of 8 Old 11-10-12, 20:04 Thread Starter
Rink675
Rink675's Avatar
Nuno!
Yea figured it wasn't that easy....although I am used to dealing with single cam engines so I wasn't sure if dual cams were different.
Thanks!
Rink675 is offline
post #4 of 8 Old 11-10-12, 20:25
wavrdr
wavrdr's Avatar
You need a degree wheel, and the know how to do it IMHO....Something I didn't want to mess with....
The guy whom did my SS topend did it as part of his "package"...
CCS Florida expert #52
Sidi boots-Forcefield Armor-Amsoil
wavrdr is offline
post #5 of 8 Old 11-10-12, 21:12
Dave73
Dave73's Avatar
+2 means 2 degrees advanced, not 2 teeth. There is a lot of trial and error to find the exact combination that works best.
I've only seen one specific recommendation...seems most builders keep this hush-hush
06 675 Track Bike
10 Tiger 1050 Everything Else Bike
Dave73 is offline
post #6 of 8 Old 11-10-12, 21:22
casacrow
casacrow's Avatar
Care to share your recommendation ?
casacrow is offline
post #7 of 8 Old 11-11-12, 01:19
A tooth off will not cause conflict with the 675 but it doesn't run right.
MacBandit is offline
post #8 of 8 Old 11-11-12, 01:33 Thread Starter
Rink675
Rink675's Avatar
I think I am in deep trouble.....winter hasn't even fully hit yet and I am already thinking of all these different ways to squeeze out a little more power here and there lol.
Rink675 is offline
