Buy a Battery Tender - Triumph675.Net Forums
Old 11-09-12, 16:58   #1
daleCarlsbad
daleCarlsbad's Avatar
Default Buy a Battery Tender
A bit of advice.
So .......... I have read so many posts on this board relating to dead batteries, electrical problems with no idea what the battery voltage is, etc. etc.
Invest in a simple $35 Tender, keep it plugged in and many of these problems will no longer be an issue. Your battery will certainly appreciate it.
I have 6-bikes in the garage and they are all on a Battery Tender....it's part of owning a modern motorcycle, just like chain lube, regular fluid & coolant changes, and a good stand.
Currently in the garage:
Daytona 675 2006 (2 each)
Bonneville 904cc 2003
KTM XC-W 250 2009
Honda CRF 230 2008
Husky TE-250 2010
Old 11-09-12, 17:47   #2
Spearo
Spearo's Avatar
If you buy a lithium-iron battery, you could probably get away without a tender. Have let it sit for 2-3 weeks before, and the voltage drop is insignificant.
Old 11-09-12, 18:21   #3
tooblekain
tooblekain's Avatar
Originally Posted by daleCarlsbad View Post
A bit of advice.
+1...very religious about this and my battery lasted as long as my D675. My Bonnie I bought back in 2008 is still on its original battery and on a tender also
Old 11-09-12, 19:22   #4
sirhosis of deliver
Since when has modern technology dictated that I need a tender to maintain reliability?
Of course on the other side of the coin, I bought a bike new in 2003 and sold it in 2009 with 75000 klm on it. Original battery. Never had a flat in 6 years.
You don't necessarily need a battery tender if you ride it regularly enough. How many of you have battery tenders hooked up to whatever you drive on a daily basis?
I suppose if you have a riding season due to the climate, only do track days or are only able to get out on your bike once a fortnight for a ride, then it may be a requirement.
Old 11-09-12, 19:25   #5
tooblekain
tooblekain's Avatar
I actually have that with my car battery since I park it in the garage. Ive had the same battery in my car for over 10 years now.
Battery Tenders are like condoms
Old 11-09-12, 19:35   #6
sirhosis of deliver
I don't let anyone else ride my toys and I have commited to them all, so I shouldn't need that level of protection.
Old 11-09-12, 19:37   #7
luciano136
My recent post about battery life was not related to the battery unfortunately :(. More than likely my stator went bad...
